Best way to apply Gelid GC Extreme
Discussion in 'Hardware Components and Aftermarket Upgrades' started by saturnotaku, Aug 12, 2019.
  1. saturnotaku
    I'm going to re-paste my newly acquired Lenovo Y530. Figured GC Extreme would be a solid choice for that since I don't want the hassle of dealing with liquid metal. What is the best way to apply it on a BGA Core i7 8750H and GeForce GTX 1050 Ti? The package comes with a small rubber spreader so do I need to do that myself, or just apply a small amount directly to the dies of each component and use the heatsink assembly to squish it into place? It has been literally more than a decade since I've applied thermal paste myself, so a push in the right direction will be immensely helpful.
  2. 0lok
    0lok Notebook Deity
    I normally spread it as thin as possible then at the middle bit I put a small very blob for the heat sink to do it's job. As long as you have a even heat sink pressure then gelid should be fine. Hope this helps. ^_^
    saturnotaku likes this.
  3. Eclipse2016
    Eclipse2016 Notebook Geek
    I put a pea-sized blob on the CPU / GPU. I also spread a VERY fine layer on the copper heatsink just so that the metal sheen disappears. I get all cores at the same temp with this method plus or minus 1 degree C.
    saturnotaku and 0lok like this.
  4. Lumlx
    Lumlx Notebook Consultant
    Put syringe of thermal paste into plastic bag and place it into cup of hot water. This will heat up thermal paste so it will be easier to squeeze it out and it will spread on cpu/gpu easier (no need to use included spreader)
    Eclipse2016 and 0lok like this.
  5. Papusan
    Use the included spatula and spread it if the heatsink mounting mechanism in this notebook is flimsy and weak(low pressure from heatsink on die).
    Eclipse2016 and Falkentyne like this.
  6. saturnotaku
    So it sounds like dab-and-squish is the best way to go. Since the die of the CPU is rectangular, rather than square, would I want to apply the compound more like an oblong grain of rice rather than a round pea?
    Ninecry likes this.
  7. Papusan
    i7 8750H is not 100% square. Use a 3/4 long thin line with paste.
    Ninecry likes this.
  8. t6nn_k
    t6nn_k Notebook Consultant
    Also applying decent pressure on heatsink so it will spread easier.
  9. electrosoft
    electrosoft Tick Tock Clarice....
    This is a mistake, as once you remove the artificial pressure, you may end up with a bad spread as the heatsink adjusts to the natural pressure from the tightened screws causing weak spots spread too thin from the
    added pressure that is no longer present.
    Best to equally, in turn, tighten each screw one turn diagonals 1-3-2-4, repeat for near equal natural applied pressure and a natural spread that will properly reflect weaker contact points with more compound.
    Nevermind the fact you run the slight chance of damaging your chip if you press too hard.
    0lok likes this.
  10. Felix_Argyle
    Felix_Argyle Notebook Consultant
    Best way to apply any thermal paste is to spread it evenly by hand. This is the ONLY way you will be sure that the paste covers the whole surface of CPU or GPU. Unless you can see through the heatsink ;-)
