Best setting overclock for RTX 2080
Discussion in 'Sager and Clevo' started by KLICHO, Aug 15, 2020.
  1. KLICHO
    KLICHO Notebook Consultant
    Hello what is good/best settings RTX 2080 overclock ? Now i have Core @ 2070 MHz on 0.975V and Mem 550 MHz +
  2. Meaker@Sager
    It varies from core to core as to the best clock/voltage.
  3. KLICHO
    Yes but if i give more core i have less turbo boost now is 1790HMz-1810MHz. If I ser 150MHz core + i have 1850-1880Mhz why. I have dual psu 330W
  4. Meaker@Sager
    Sorry I could not understand your question, due to power limits there will be a balance usually on votage/clocks to get the best point.
    Again the exact point varies from core to core.
  5. KLICHO
    Ok Can i beat the Power Limit ?
  6. Meaker@Sager
    You can shunt mod the card I suppose but max clocks are around 2100mhz due to clocking limits too.
    You need to be very careful your VRMs and core are being cooled well.
    Vasudev and Papusan like this.
  7. KLICHO
    I know i use one off the best thermal pads and radiators on heat sink
