Best PCIe WiFi Card
Discussion in 'Networking and Wireless' started by ahl395, Feb 14, 2016.
  1. ahl395
    ahl395 Ahlball
    Hello, been awhile since I posted a thread!
    My knowledge on current tech has fallen off quite a bit so I am looking for some assistance.
    I need a new Wifi card (PCIe half size) for my Asus G73SW. I am looking for the best one available. I currently have an Intel 6200 that sucks pretty badly. My phone right next to my computer gets 80+Mbps on Speedtest while my computer gets 10-20Mbps.
    I have a Xfinity AC/N Router, while I think N is plenty sufficient, if there's a good AC card that will work better I'm open to all suggestions. Range & speed seems to be my main problem.
    Thanks in advance
  2. downloads
    downloads Super Moderator Super Moderator
    Intel 7260 would be my bet - it got to a rough start but they finally fine tuned the drivers.
    Are you using 2.4GHz band with your Intel 6200?
    ahl395 likes this.
  3. ahl395
    ahl395 Ahlball
    Okay thanks, I'll look into that one.
    Yes I believe I'm on 2.4Ghz since the whole 5.0Ghz doesnt like going through walls thing, lol. Quite a few walls to go through. I admit that I'm in a somewhat bad spot with my router. Router is downstairs and I'm upstairs on the other end of the (small/medium sized) house. However my phone has zero problems with this so i know something's up with the card in my computer.
