Best monitoring software for GPU and CPU?
Discussion in 'Gaming (Software and Graphics Cards)' started by Oshiruko, Aug 15, 2012.
  1. Oshiruko
    Oshiruko Notebook Enthusiast
    What's the current best, easy to use, monitoring software for GPU and CPU temps? I'm looking for something that has on-screen display of the temps.
  2. Seanzky
    Seanzky Notebook Evangelist
    Have you tried MSI Afterburner?
  3. jaug1337
    jaug1337 de_dust2
    Well that basically summed it up :D
    If that doesn't work.. EVGA should do it ;)
  4. fenryr423
    fenryr423 Notebook Evangelist
    AB wont monitor CPU temps to my knowledge...
    sean your picture is terrifying
  5. MrDJ
    MrDJ Notebook Nobel Laureate
    monitoring software in my sig below :)
  6. Oshiruko
    Wow, that's a big list of software. Which one do you recommend for easy-to-use CPU+GPU monitoring with on-screen display?
  7. MrDJ
    HW Monitor is good and also cpuz/gpuz
    they are all free so just try them and then delete the ones you dont like.
  8. Oshiruko
    I downloaded HW Monitor, and I can't see an option to make an on screen display overlay. Does it not have that capability? Also, does it have an option to monitor FPS?
  9. MrDJ
    no it runs in the background so you have to close game page down to see it.
    use fraps to monitor fps (on same page)
  10. Oshiruko
    What's the best on screen display monitoring device?
