Best long lasting Thermal compound?
Discussion in 'Sager and Clevo' started by Danishblunt, Dec 5, 2018.
  1. Danishblunt
    Danishblunt Guest
    So I have tested so many thermal compounds lately it's basicially insane, I am trying to find a thermal compound that not only performs well (a lot do extremely well) but also lasts. I experience on mmy CPU that the thermal paste tends to pump out after a while. I tried the following thermal compound only to have reduced performance after a couple of months:
    - GC-Gelid
    - Kryonaut
    - Coolermaster HTK 3 (its a cheap one)
    - Arctic MX 2 & 4
    - IC Diamond
    - Noctua NT-H1
    I ordered coolermaster Mastergel, which will hopefully get here by friday and see how that goes.
    I did a 10minutes aida64 test and the temperature is basicially abysmal given my notebooks cooling solution, this is the Prolimatech Pk 3 after ~1.5months (temps shouldn't be this high):
    I hope the mastergel will do a better job. So far only conductonaut/LMU was able to stay at the same performance for months without degrading.
    I'll keep you updated.
    Vasudev, c69k and jaybee83 like this.
  2. Meaker@Sager
    Conductonaut is pretty stable but it might be worth adding some washers if you notice it pumping or aerating too much.
    Vasudev and Papusan like this.
  3. kothletino
    kothletino Notebook Consultant
    Thermal Grizzly Conductonaut(LM) on 6820hk(after about 1 month) in ms-1785 with fans speed on auto:
    Vasudev likes this.
  4. Danishblunt
    Danishblunt Guest
    Wow, that's silent mode indeed, a little hot for a GT 72. What temps you getting on agressive fans?
    also how much watts does your CPU need when running aida64?
  5. kothletino
    Here you go, fans with full speed:
  6. Danishblunt
    Danishblunt Guest
    Arent you able to see the wattage of your CPU in HWinfo?
    But yeah, thats expected of an MSI notebook with liquid metal and full fan :D
    Whats the highest clock you could manage on the notebook?
  7. Chastity
    Then what are you doing wrong with ICD7? I repasted a G73JH, and I got the same level of cooling after 5 years of usage off the same paste job, never redone. My 1710 was repasted a year ago, and it still performs as well.
    If your ICD7 job is degrading, then something is wrong.
  8. Danishblunt
    Danishblunt Guest
    It is just pumping out somehow.
  9. Chastity
    When I apply it, I just dab it in the middle, about the size of a large pea, and I don't spread it. With ICD7, it's ok to put too much because it won't lose thermal capacity, and it's non-conductive. Just plop in the middle and attach heatsink, and let the thermal heat spread the TIM.
    IIRC, you like to spread your TIMs. Big no-no for ICD7.
    For rectangular chips, a line lengthwise 3/4 the length of the chip works well. No spreading. :)
    Arrrrbol likes this.
  10. Danishblunt
    Danishblunt Guest
    Not quite, I never spread with ICD because i can't, it's way to thick. Also I do just put a line in the middle through the GPU die.
