Best light, laptop with HDR, touchscreen and stylus
Discussion in 'What Notebook Should I Buy?' started by dimonoid, Apr 27, 2019.
  1. dimonoid
    dimonoid Notebook Enthusiast
    Hello,
    I am looking for a convertible laptop with 14-15 (or even 17?) inches display. 13inch laptops are too small for my tasks. I DON'T need a dedicated GPU, as I have a separate computer for games and power-intensive tasks. CPU can have only 2 cores.
    Should have 8 gigs of ram.
    It must have at least 400nits of brightness and must have stylus support. Better if it has quad hd display or even 4k.
    Also the weight should be smaller than 1.4kg/3pounds.
    Sounds impossible, right?
    Here are some models I found:
    The lg gram 15 and 17 inch versions do not have touchscreen, so no stylus also.
    Lg gram 14 inch has only 300nits display.
    Dell xps 15 is too heavy, as it comes with gpu.
    Mac pro 15 is too heavy, no touchscreen, and too expensive
    Microsoft surface 6 pro has too small display (12.6 inches)
    ThinkPad X1 yoga in top configuration looks good, but it also then becomes quite expensive.
    Do you know any other models which could fit my needs? Please propose variants with any price.
  2. amirbahalegharn
    amirbahalegharn Notebook Consultant
    you can use "noteb.com" advance search to find the right notebooks.
  3. dimonoid
    Probably I will just wait for the ThinkPad x1 carbon yoga 4th gen, which should be coming in around 2 months. They are promising 500 nits display.
  4. DannyB513
    DannyB513 Notebook Evangelist
    I have the Lenovo C930 with 4k screen. You will not find a better sounding small convertible(has a built in 4 speaker Dolby Atmos soundbar). Has Dolby Vision, but not 400nits of brightness.
  5. dimonoid
    Thanks, but it looks like c930 has pretty dim screen, only 270 nits.
  6. JRE84
    JRE84 Notebook Deity
    Hdr laptop...lol...x1 carbon..I think that's it for choices....do you work for Lenovo or something
  7. JRE84
    You want hdr yet you mention non hdr laptops
  8. dimonoid
    No) I just have X1 carbon 4th gen, and it has pretty damn dimm screen while I frequently find myself working in bright environment, but I like everything else especially that it is very light. I don't want to buy anything smaller and much heavier than my current laptop, and that is why I am asking
  9. dimonoid
    Are you about lg gram? All the others should have quite bright screen options according to reviews.
  10. JRE84
    The x1 carbon hdr screen is 500nits...crazy bright
