Best Laptop for 3D Modelling & CAD & Adobe Suite
Discussion in 'What Notebook Should I Buy?' started by Benjamin Kang, Apr 16, 2019.
  1. Benjamin Kang
    Benjamin Kang Newbie
    Hello I am an architecture student and need a new laptop.
    The software I frequently use are the following:
    - AutoCAD
    - Rhino 3D & Vray
    - 3Ds Max
    - Revit
    - Adobe Creative Suite
    1) What is your budget? 1500$ - 2500$
    15" - 16" screen (I am a student and cannot carry 17" laptop.
    3) Which country will you buying this notebook?
    USA
    a. Like: I was looking at msi ws 65 but I really dont know. Open to any suggestions.
    No
    - AutoCAD
    - Rhino 3D & Vray
    - 3Ds Max
    - Revit
    15 inch. Weight doesnt matter.
    8) Will you be playing games on your notebook? (If so, please state which games or types of games?)
    No
    Doesn't matter
    11) What OS do you prefer? Windows, Mac OS, Linux, Chrome OS, etc.
    Windows
    Screen Specifics
    12) What screen resolution(s) would you prefer? (See further below for explanations.)
    Full HD (1920x1080) or higher
    Build Quality and Design
    No but I would prefer decent build quality. One thing msi concerns me is people saying their build quality is relatively cheap. I do not know if this is true though.
    Notebook Components
    15) How much hard drive space do you need?
    I do not need much space because I typically backup on cloud storage and portable hard drives and delete past semesters works.
    Timing, Warranty and Longevity
    16) When are you buying this laptop?
    ASAP
    17) How long do you expect to use this laptop?
    4 years or more
    Thank you guys! :)
  2. jeremyshaw
    jeremyshaw Big time Idiot
    I do not really have an informed suggestion; just leaving some options on the table for you.
    At $1500, you have enough to get a Lenovo P52 with a 6core Intel and a Quadro P2000, at current pricing (Tax Refund Sales for Lenovo). Dell Precision 7350 with a 6core Intel and a Quadro P2000 (also some sales promotion going on). Either laptop is each company's respective workstation, not a rebadged business/consumer laptop, like the P52s, Precison 5530, etc. Both of them can be loaded up a bit with critical options (big battery and 72% NTSC gamut screen for the Dell).
    I'm leaving off RAM upgrades, since I have no clue what the actual requirements are anymore for 3D modeling applications. Extra bits of the budget can be used for RAM, warranty, and other niceties.
    Either laptop is on the big and heavy side, even for a 15.6" laptop. Somewhere around ~7lbs when including the power brick. Both have large threads with some community around them, on NBRf. Even Reddit cannot provide that for workstation laptops.
    http://forum.notebookreview.com/threads/any-thinkpad-p52-owner.821658/page-17
    http://forum.notebookreview.com/thr...0-owners-thread.820539/page-219#post-10897372
  3. Benjamin Kang
    Hi thank you for the reply.
    I am looking to buy something with 16gb + of ram.
    Also, I'm looking at the lenovo and I'm conflicted whether to buy the one with quadro p2000 or p3200. Is there a big difference in terms of performance because I see a big difference in pricing. Is it worth the money? I am leaning towards the lenovo p52 for now from your advice but if any other people want to recommend me otherwise that would be appreciated. Thank you!
  4. rlk
    rlk Notebook Evangelist
