best intel wifi card with bluetooth?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by jedisurfer1, Feb 6, 2013.
  1. jedisurfer1
    jedisurfer1 Notebook Deity
    Is this the 6235 or 6230? Is there a difference between those two? I think the 6235 has bluetooth 4.0 but I'm looking for the most stable connection card. Do any of these have known problems?
    Thanks
  2. Misdemeanor
    Misdemeanor Notebook Consultant
    Go with the 6235 for BT 4.0 and for reliability and it has very good reviews. If you can afford it try to get a Ultimate-N 6300, unfortunately it doesn't have BT.
    Advanced-N 6235 Brief
    Advanced-N 6230 Brief
    Ultimate-N 6300 Brief
  3. Prostar Computer
    The Intel Advanced are very good combo cards. Killer makes a good card too, albeit some driver issues.
  4. Misdemeanor
    gizmo22 is selling an Ultimate-N 6300 for $30. LINK
  5. Qing Dao
    Qing Dao Notebook Deity
    Get the 6235. The regular wireless part of the 6230 and 6235 is exactly the same.
  6. StormJumper
    StormJumper Notebook Virtuoso
    Would that work with a HP DV5-1000 series???
  7. Prostar Computer
    As long as it's the same connection interface, it should work just fine.
  8. Pirx
    Pirx Notebook Virtuoso
    Hah, no, watch out! I happen to go through an ordeal with my daughter's HP Pavilion DV7t right now, and one of the niceties of HP laptops is that they check your wireless card against a Whitelist they have in their BIOS. If you try to put in the wrong card, the laptop will not start. What's even better is that it appears that, not only do you need to have the right card, you also need to buy it from HP, otherwise it won't work. Finally, there seem to be cases where a card is listed as compatible in the manual incorrectly, so it may not work either way. No further comment...
  9. davidricardo86
    davidricardo86 Notebook Deity
    On a somewhat related note, for the heck of it I just tried a Dell Ericsson WWAN adapter in my HP ProBook 6475b and got a message that the WWAN was not compatible and it was disabled. I agree with Pirx, make sure the WIFI card is compatible.
  10. joeyboy
    joeyboy Notebook Enthusiast
    6235 for BT 4.0 is been very good for me :)
