Best inexpensive way tor remove scratches??
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by darthmonkey, Mar 21, 2009.
  1. darthmonkey
    darthmonkey Notebook Enthusiast
    So whats the best way to remove scratches from my laptop cover??
    My laptop cover is scratched up pretty badly, so I'm looking for an inexpensive way to remove the scratch marks.
    I heard that some people use ScratchDocter. I haven't tried it yet, but I would like to know if there are better alternatives I can get if ScratchDocter is not the best.
  2. elijahRW
    elijahRW Notebook Deity
  3. darthmonkey
    Would is still work if I use only Meguiar's Scratch X??
  4. avanish11
    avanish11 Panda! ^_^
    it should work, but make sure you clean off the plastic with soap/water, then isopropyl alcohol after that.
  5. Cin'
    Cin' Anathema
  6. spradhan01
    spradhan01 Notebook Virtuoso
    It looks nice but its hard to see scratches on M17 so hope I will not need it.:D
  7. CompUG
    CompUG Notebook Evangelist
    would that guide work for my Gateway m6862?
  8. kapblp
    kapblp Notebook Enthusiast
    What a great guide. Too bad I ran out of patience! <g>
  9. jackluo923
    jackluo923 Notebook Virtuoso
    My method is "free":
    1. Put about about 4 Pea sized dab of tooth paste on the cover of your laptop, spread them out with your fingers until the cover is covered
    2. Use a damp microfiber or regular damp towel to rub the laptop cover in circle motion. Once you give it a thorough rub, turn the towel upside down and rub with the clean side again until there's no more toothpaste visible.
    3. Clean your towel, then rub with your damp clean towel on the laptop cover to remove any residue
    4. Rub the laptop cover with a bath towel to remove the water vapor and prevent drying/evaporating mark.
    For more "badly scratched" laptop cover, if you're going to use the toothpaste method, you'll need to rub for a long time.
    Using this method, i was able to restore my badly scratched glossy acer apsire one to mirror finish with no visible scratch. Even fogging it up with my breath doesn't reaveal any scratch.
  10. CompUG
    ^anyone ever tried that?
