Best and silent 120mm radiator fans?
Discussion in 'Desktop Hardware' started by ekkolp, May 19, 2019.
  1. ekkolp
    ekkolp Notebook Evangelist
    Guys what fans do you commend for a silent operation and good static pressure? Maybe Noctua NF-F12 PWM?
  2. Convel
    Convel Notebook Deity
    Though not inaudible, the Noctua NF-F12 industrialPPC-2000 PWM tends to be a good compromise between noise and static pressure for a 120 mm radiator fan. If you don't mind the colour and know you'll never need more than 1500 RPM, the non-industrial NF-F12 PWM as you suggested is not a bad choice either.
    ekkolp likes this.
  3. ekkolp
    I finally ended up with NF-F12 PWM, so far so good.
    Convel likes this.
