BD-drive wont read any discs...Help!
Discussion in 'VAIO / Sony' started by loesch0116, Jan 12, 2010.
  1. loesch0116
    loesch0116 Newbie
    I have a Sony Vaio laptop that has a blu-ray drive in it (Optiarc BD ROM BC-5500S4) which will not read any discs. It had been working fine a few days ago, but now any time I out a disc in, or even when I just open and close the disc drive, it makes a pulsating noise. It is sort of like the noise it would make if it were starting to spin and read the disc, but pulses for about a minute. I can see the icon for the drive in the my computer window, but never a cd or dvd. If I click on the icon for the drive, it pops up a window that says please insert disc.
    All of my firmware is up to date, and in the device manager it says the device is working properly.
    Does anybody have any idea what might be going on? Any help would be greatly appreciated!
  2. H.A.L. 9000
    H.A.L. 9000 Occam's Chainsaw
    It this happening with just Blu-Ray disks or with other media as well? Also with the drive empty, go to "My Computer" and what type of drive does Windows say it is... like BD-ROM or DVD-RW...etc?
  3. loesch0116
    loesch0116 Newbie
    It happens with cds and dvds as well. With no disc in the drive, it comes up as BD-ROM Drive.
  4. H.A.L. 9000
    Have you done a clean install of Windows? If so you might could try updating your chipset drivers... that usually solves some problems.
  5. MelodyMaster
    MelodyMaster Notebook Deity
    That pulsing noise sounds like the laser assembly is hunting, trying to focus on the disc but not finding it. If you're lucky a bit of fluff is stuck to the lens, try blowing it off or cleaning it; if you're unlucky the laser has failed, or the lens has been banged out of place by the drawer opening or closing before the laser has parked.
  6. sanches
    sanches Newbie
    I have this exactly problem. Have you solved it?
    Once I restored my computer to it's factory settings, and the drive were ok after that!
    But now it's dead again. I guess it's a problem about compatibility with some software.
  7. michaelsonline
    michaelsonline Guest
    are you using an iso mounting software at all.
    I was using Virtual Clone Drive and it caused huge problems with my Mata BD-MLT UJ-220S. Drive would not read cds, would fail 75% with burning media. Constant Seeking when trying to read a disc. Uninstall the software and reboot, Problem went away.
    Hope this helps
    Michael
  8. sanches
    sanches Newbie
    maybe that's the problem
    I had this software once (maybe it broke something here!). But I unninstalled it several weeks ago. My drive has been broken for two months.
    Is there anything else I can do to really remove it?
    I already unninstalled daemon tools also. But I'm sure the drive was working after I installed Daemon tools and before I installed Virtual Clone Drive.
  9. michaelsonline
    reinstall the application, reboot, uninstall with say Revo Uninstaller, reboot
    maybe that will clean the broken install?.
  10. sanches
    sanches Newbie
    it didn't work! I still have a dead drive that is forever seeking for some media.
    thanks anyway!
