Battlefield 3, Area-51 m15x (2009), AlienFX Problem
Discussion in 'Alienware Area-51/Aurora and Legacy Systems' started by SniperTNT, Apr 27, 2012.
  1. SniperTNT
    SniperTNT Notebook Consultant
    I was starting my system up today, and discovered that Battlefield 3 had a patch. I downloaded it, and started the game. When my AlienFX lights went out, I assumed that the patch created support and links between the game and the AlienFX board. I wanted to test it out.
    Then it got bad. I kept hearing a noise similar to the noise you get when you take your USB input out of your computer and put it back in. Not only that, but it kept going on and off, and the lights never stayed completely on. The game is unplayable also, because all of the memory is taken up by this.
    Anyway, is there a way to fix the problem where it is disconnecting and reconnecting and making that noise? It would be much appreciated.
  2. daminibeast
    daminibeast Notebook Geek
    Well I can’t really answer your question. (Well maybe) but first, how are you able to play BF3 on your area 51? You have a 3870m?
    Anyways, try a system restore. (Start menu, Accessories, system tools, system restore.) Restore it back to a date before you installed the patch. Should fix it. I haven’t had the problem myself (don’t even own bf3) but it’s something you can try.
  3. SniperTNT
    I am able to play it on medium settings at a consistent framerate of 30-35 FPS, which for a 512MB card I think is pretty good.
    I tried that and it didn't work. It has to do with the driver and the firmware. I tried to set the Alienware Command Center and the firmware (AlienFX) back to an earlier version. I hope that does something.
    SPECS for my system (Area-51 m15x)
    GPU - ATI Mobility Radeon HD 3870 512MB
    CPU - Intel T8100 2.1Ghz
    3Gb RAM
    7200RPM HDD
  4. megamicrofish
    megamicrofish Newbie
    Dude, What graphics driver are you using ?
  5. SniperTNT
    For my ATI mobility radeon 3870, I am using the latest catalyst suite which is 12.4
