Battery Wear
Discussion in 'Asus' started by BENDER, Apr 6, 2006.
  1. BENDER
    BENDER EX-NBR member :'(
    NHC sayz my battery wear level is 16% :eek: and my V6J is only one month old. Is that normal?:confused: I've done a recalibration and it still shows up as 16%. Is there a way to bring it down to 0?
  2. Johnny9ball
    Johnny9ball Notebook Evangelist
    16% after a month that dosent sound right.
  3. BENDER
    Its less than a month actually ><;
    Long story. To cut it short, its a replacement notebook which i got on 23/03/2006 for my DOAed lappy <<;
  4. MysticGolem
    MysticGolem Asus MVP + NBR Reviewer NBR Reviewer
    NHC is getting some wrong numbers bro, but i have heard that calibrating increases wear... but i dunno, this is one thing im gonna be puzzled about when i get my laptop.. is battery wear ?? =\
    try recalibrate? also drain battery then charge to full, turn ur laptop off and then get another reading, also test if your batterylife decreased from the day of purchased? by 16%?
    So for example right when you get ur laptop you should bench ur laptop, and see how much batterylife you get and 3dmark05, tthen after every now and then keep testing to see how effecient your laptop is..
    So check out all of that.
    Thanks,
    MysticGolem
  5. BENDER
    Mystik, i did a recalibration and it didnt help :(
    Can any1 check the full capacity charge on their V6J?
    NHC sayz
    Any other application can i use to cross check the battery wear?
    :confused:
  6. flanken
    flanken Notebook Evangelist NBR Reviewer
    You can download Mobilemeter (google for it).
    However, I've found that Mobilemeter generally agrees with NHC; I think they use the same protocol to communicate with the battery. My wear level is 13% after 4 months of use; it really went up early on, but has held steady for the past several months.
  7. BENDER
    Yep, Mobilemeter agrees with NHC. Battery wear is still 16% :confused:
    Is a 16% battery wear normal for a less than a month old notebook?
  8. drak0n
    drak0n Notebook Geek
    Hmmm, my z70va is about a mth old and the battery is at 1%, although I did have it replaced after a week of use.
  9. coriolis
    coriolis Notebook Nobel Laureate
    Take the battery out, blow or wipe the contacts, then put it back in, see if that changes anything
  10. BENDER
    I blew it, I wiped it, I shook it, but still 16% wear ><;
    Cori, what's the designed capacity for your battery?
