Battery Replacement, Clevo P870TM1 = P870TM1-G?
Discussion in 'What Notebook Should I Buy?' started by bogomips8700, Jan 5, 2018.
  1. bogomips8700
    bogomips8700 Newbie
    Hi All,
    Trying to decide between a Clevo P775TM1 vs. P870TM. The problem is that the P870TM has a gunked-in battery and needs 9 screws removed to get at it. The P775TM1 is apparently "normal" for battery replacement. The battery is apparently replaceable but with some work. However sourcing the battery seems to be a pain...
    I don't see HIDevoluation selling the replacement battery, but I see that Sager sells one with the correct watt-hour rating (89Wh) for their NP9877 model which is the Clevo P870TM1-G. On the Clevo website to download drivers, both models show up on the same dropdown box, so I'm starting to think all of the P870TM / P870TM1 / P870TM-G / P870TM1-G could use the same battery, but I cannot verify. Can anyone else verify this? Could someone post a picture of their battery?
  2. sicily428
    sicily428 Donuts!! :)
    That -G means g-sync. All those configurations use the same battery
