Battery problem - ACER ASPIRE 5050
Discussion in 'Acer' started by vimarygonzalez, Dec 21, 2008.
  1. vimarygonzalez
    vimarygonzalez Newbie
    Hola:
    Si alguien pudiera ayudarme estare agradecida. Tengo una Aspire 5050, que me esta dando problemas con la bateria. Comenzo descargandose muy rapido...no duraba ni 15 minutos la bateria. Ahora si le pongo la bateria y le conecto el cable o si la uso solo con la bateria se friza y el mouse pad no funciona. Pero si la conecto sin la bateria puesta...solo con el cable de AC si funciona a la perfeccion. Creo que la bateria se murio...pero quiero estar segura antes de comprar otra... Gracias.;)
  2. ATG
    ATG 2x4 Super Moderator
    OP post English translation: Hi, if someone can help me out here it will be most appreciated. I have an Acer Aspire 5050 which is causing me problemS lately. The battery is discharging very quickly can't stand even 15 minutes. Now if I power on the laptop with the battery placed the laptop refuse to boot but if I remove the battery(only the AC cable is plugged in) the laptop boots, no problem whatsoever. I think my battery is dead but I want to be sure before I go to the store a buy a new one. Thank you.
    Welcome to NBR
    You have to write in English or at least provide a translation on this forum, it's a English only forum.
    Anyway yes, I think your battery is dead, you need a new one. MAKE SURE YOU GET A GENUINE ACER BATTERY OTHERWISE IT MAY NOT WORK!
    My post Spanish translation:
    Bienvenida en NBR.
    Tienes que escribir en Ingles o por lo menos dejar una copia traducida en Ingles de tu mensaje, este foro solo admite Ingles.
    Sobre tu problem: Si, yo creo que tu bateria esta muerta, tendras que comprar una nueva. ASEGURATE QUE LA NUEVA BATERIA COMPATIBLE CON TU PORTATIL, LO MEJOR ES COMPRAR LA DE ACER O SI LA COMPRAS SEGUNDA MANO - QUE SEA DE UN PORTATIL ACER!
