Battery Light blinking at 'near' full charge...
Discussion in 'Dell XPS and Studio XPS' started by thumper300zx, Feb 2, 2012.
  1. thumper300zx
    thumper300zx Notebook Consultant
    My XPS battery light is blinking (four short orange, long white) when close to fully charged. It will never get to 100% (98 or 99 and stops charging). When I unplug the AC adapter, it continues blinking for a while until the battery discharges a bit, then it stops.
    I was under the impression the blink code was on a failing battery, but the battery is charging near full and holds a charge, and blinks when near full instead of immediately when AC is plugged in.
    Any ideas? I called Dell on this and I can send it in RIGHT before my warranty expires, but I'd like to know what the problem is.
  2. Commander Wolf
    Commander Wolf can i haz broadwell? Super Moderator
    Is this an M1330 or M1530? Is the battery genuine or aftermarket? Does this happen with other batteries, if you have any others with which to test?
  3. thumper300zx
    Actually, it's an L701X.
    Also, when I boot up, after the Dell Splash screen, it gives me two beeps and prompts me to press (with associated messages)
    F1
    F2
    F12
  4. mknott
    mknott Notebook Enthusiast
    I dont have a clue with the battery light flashing etc but two beeps at the start could be related to the cmos battery. what messages are given for the F1, F2 and F12.
    im guessing F1 may be something like boot normally, F2 enter bios and F12 boot options.
  5. thumper300zx
    Correct. F1 = continue, F2 = Setup/Bios, F12 Boot options.
    Anyway -- I'm just gonna send it in -- may as well.
  6. beriaanirudh
    beriaanirudh Newbie
    hey thumper300zx.. i have dell XPS and i m facing exactly the same problem as u did , but my warranty has recently expired :( .. can u plz let me know how to solve this thing.. ??
  7. mknott
    does it give you any message or just beep and display the f1 f2 f12?
  8. mknott
    according to the manual, 2 beeps means no ram detected however if no ram was detected it wouldnt show the F1, F2, F12 options.
    can you confirm that the correct amount of ram is found.
  9. beriaanirudh
    beriaanirudh Newbie
    hey mknott... i didnt check the ram .. and it does display f1, f2 and f12 at start ( only when battery near full) .. but my problem is the minor one : the blinking battery display at near full.. everything else is fine : the battery , backup, charging... blinks is the only prob..
  10. virtual_teenstation
    virtual_teenstation Newbie
    I am having exactly the same problem with my Dell XPS L701x.
    did you find any solution for your problem. If yes - kindly share that with me.
    thank you
