Battery latch broke, does this affect my battery?
Discussion in 'Hardware Components and Aftermarket Upgrades' started by sabby, Oct 16, 2007.
  1. sabby
    sabby Newbie
    I've just had my Toshiba Satellite for about a year now (the warranty just expired last week which does not help me.) In a year, I noticed that I lost about an hour and a half charge of the battery, so I went to take it out to see the model number (to get a new battery) and a little black piece fell out with it. It was the right side latch that had broken off at some point, so only the left side locks. I realized a while ago I had about 2 hours of charge, but now I only have barely an hour of charge under the same circumstances (wireless off and such). Could the broken latch have caused the reduction in charge, or did it just even out. Can I fix the latch myself? I don't think gluing it will do any good obviously, I can't even get into there but I don't know if I have to purchase just a part for the latch or a whole new bottom.
  2. nizzy1115
    nizzy1115 Notebook Prophet
    its normal for battries to lose full charge, only fix is a new one. the latch you can repair them yourself, although they are a bit tricky...
  3. allan_huang
    allan_huang Notebook Deity
    No, it won't, as long as the connectors are touching, it will be fine.
