battery charge state light
Discussion in 'Alienware 14 and M14x' started by toondw, Jul 27, 2011.
  1. toondw
    toondw Notebook Consultant
    Got my new M14x, lovely, works well and put together well.
    I have noticed the battery charge indicator on the bottom does not work, i'm not concerned as i can see how much charge is present when i have it turned on but i'm curious.....Has it not been activated or is there a software fix?
    Cheers
  2. CGSDR
    CGSDR Alien Master Race
    You might want t press it harder, for mine I have to press it very hard, sometime I felt like I might break it, lol.
  3. Marcymaru
    Marcymaru Notebook Consultant
    What do you have to press exactly? I can't find any button... O_O
  4. soulhacker
    soulhacker Notebook Consultant
    turn the laptop over and directly above the fan there is a little slit with a picture of a battery and 5 squares which should light up when you press the the little slit, indicating how much battery remains
  5. toondw
    Crikey! Your right, you have to press really hard! It works!
    Cheers
  6. CGSDR
    You're welcome! :)
  7. niko2021
    niko2021 Notebook Evangelist
    Yeah the light is actually on the battery itself. If you unscrew the bottom, you'll see the button and lights on the battery, pretty neat design.
  8. Marcymaru
    Found it, thanks!!! :)
  9. kimjonathanh
    kimjonathanh Notebook Enthusiast
    Thanks! This helped me too! :D
  10. eats7
    eats7 Notebook Evangelist
    i just put a small piece of duct tape on the inside of the backplate, over the button, so now i dont have to press as hard. works well.
