Battery calibration on a CF-M34, how?
Discussion in 'Panasonic' started by User32, Jun 8, 2019.
  1. User32
    User32 Notebook Deity
    M34 Mk7 with a rebuilt battery from BatteryRefill, HWiNFO says it's got 20% wear and yet it shuts down after nearly a hour with the red battery light coming on, even with the CPU having a hefty undervolt.
    How do I recalibrate the battery on this thing?
  2. Shawn
    What OS?
  3. Springfield
    Springfield Notebook Deity
    CF-M34 Mk7: In BIOS setting, Exit tab, at the bottom you should see Refresh Battery. I believe it reboots after that and runs the recal.
    In my experience the CF-M34's don't have a long battery life, only 2x3 AA cells, so unless the refurb battery is using Panasonic cells (very high quality) that may be about what you can expect.
  4. User32
    XP SP3
  5. Shawn
    From what I know, Battery recal just sets the OS battery meter to match the actual battery usage.
    Either find a 3rd party util or try a battery recal util for xp from a different model Toughbook.
  6. Shawn
  7. User32
    Seems to have worked, I got a Refresh Battery option in the BIOS.
  8. Shawn
    What worked?
    The link I provided?
    Springfields suggestion about the bios?
  9. User32
    Your link and then going into the BIOS after installing the brecal software.
    EDIT: Battery's effed, it still only lasts for about an hour.
