Base System Device
Discussion in 'HP' started by NateCohen, Jan 11, 2007.
  1. NateCohen
    NateCohen Notebook Enthusiast
    I just installed Windows Vista on my HP Pavilion DV6000 and in the device manager I have an unkown device and the name of it is a "Base System Device". Does anyone know what this could be?
  2. bal3wolf
    bal3wolf Notebook Consultant
    did you install all the drivers that came with your laptop ?
  3. fdlazarte
    fdlazarte Notebook Consultant
    the driver is on your SWSetup folder... im sorry i forgot the folder name for that driver but you can let Vista search it for you on your driver update
  4. JadedRaverLA
    JadedRaverLA Notebook Deity
    Did you install 32-bit or 64-bit Vista? If 64-bit I'm amazed it's only one. If 32-bit, it'll either be QuickPlay buttons or card reader drivers. Either way, on Vista 32-bit you should be able to use your XP drivers from the SwSetup directory for now.
  5. ThunderRiver
    ThunderRiver Notebook Consultant
    It is the HP QuickLaunch buttons. Just run Windows Update, I had the same issue until earlier this week when Vista automatically installed the driver for it.
    Now, all I am missing is QuickPlay and Audio drivers.. hurry up HP!
  6. gridtalker
    gridtalker Notebook Virtuoso
    Where is everyone getting Vista from?
  7. BENDER
    BENDER EX-NBR member :'(
    The base system device could also be your memory card reader :)
  8. fdlazarte
    i have MSDN subscription and im testing vista rtm web devt
