Base System Device?
Discussion in 'HP' started by P4rD0nM3, Dec 16, 2007.
  1. P4rD0nM3
    P4rD0nM3 Notebook Enthusiast
    I did a clean Vista install and went from a 32 bit to a 64 bit Vista.
    Once Vista is done installing, I updated it and then installed Quick Play and Quick Play buttons.
    When I look at Device Manage, I have two unknown devices.
    Their locations are:
    PCI bus 7, device 9, function 2.
    PCI bus 7, device 9, function 3.
    I was wondering if you guys know what they are. TY!
  2. MegaMan X
    MegaMan X Notebook Evangelist
    memory card reader most likely....try pointing the driver installation where you have your updated rioch's memory card reader drivers
  3. timtravel42
    timtravel42 Notebook Virtuoso
    did you install all of the drivers in the SwSetup folder
