bad Benchmark score HELP!
Discussion in '2015+ Alienware 13 / 15 / 17' started by FaTT, Nov 21, 2017.
  1. don_svetlio
    You can check for youself - use Afterburner and see if your CPU is hitting 100% usage along any of the cores.
  2. FaTT
    FaTT Notebook Consultant
    okay so I used afterburner, with fallout 4 1080p ultra everything max distance on everything I couldn't get a SS because the SS was not showing the afterburner OSD but while I was watching the highest any of my cpu got was 75% and it was only for roughly 3 sec, other then that no more then 50-55% in battle so its not a bottleneck
  3. FaTT
    well I got a SS with ab osd in windowed mode
  4. don_svetlio
    The GPU is also running at 60% only so there's something holding it back.
  5. FaTT
    heres a few inside heaven 4.0
    it got up to 80 but didn't go past that
  6. gschneider
    gschneider Notebook Evangelist
    @FaTT just check you have the latest bios and video card drivers. Then check your commend centre and AGA drivers.
    You have seen my scores in my mini review thread? I have direct links to. Time spy and fire strike scores you can use as a benchmark.
    When gaming I'm gaming at 3440x1440p so I'd need to know the games you play so I can benchmark FPS with you.
    Download Fraps for FPS
    For OSD I'm using Eva's presion xoc software.
  7. Vasudev
    Benchmarks are crap and drivers are optimised so that users get more scores but on gaming it will be more thorough and you can monitor everything using HWINFO or GPUz.
    So, try a game like Witcher 3 or GTA V.
    speedsweep likes this.
  8. pathfindercod
    pathfindercod Notebook Virtuoso
    Are you using the laptop lcd with the AGA or an external monitor plugged into the GPU/AGA?
  9. FaTT
    my laptops 4k display although I don't use 4k only 1080P its the laptop in my sig, the only difference is that they sent me a 1080 instead of the ti the ti will b here friday
  10. FaTT
    thank you for your response my friend but I K I have all of the newest drivers, when I purchased this laptop(actually a trade you wouldn't believe what I traded for it) the previous owner was a porn addict, and this PC had no recovery partition(due to previous owner not knowing what he was doing) so I had to re DL win 10 from dell and put it on a flash and completely reformatted the system and at that time I also downloaded all of the newest drivers then when I got the 1080 the other day I downloaded nvidias newest driver 368.25
