AW18 using Desktop GTX 970 EGPU Setup
Discussion in 'Alienware 18 and M18x' started by Scanner, Mar 16, 2016.
  1. Dr. AMK
    Dr. AMK Living with Hope
    Cooler Master Notepal U3Plus Laptop Cooler "R9-NBC-U3PK-GP, 3 x 80 mm removable fans, aluminum surface
  2. tharok2
    tharok2 Notebook Enthusiast
    Is this the same one you are using in the photo? From the photos it looks very different. No usb or ports like from your photo. Is that a separate dock your using?
  3. Dr. AMK
  4. tharok2
    That looks more like it. Which one is better in your opinion?
  5. Scanner
    Scanner Notebook Deity
    The laptop cooler that I was using in the photo was the Cool Master Storm SF-19 with 2 140mm fans. Unfortunately, the model is discontinued. Once I removed the GPU and used the external 970 the was no heat problems.
  6. aaronne
    aaronne Notebook Evangelist
  7. hstpctech
    hstpctech Newbie
    hi Scanner,
    is it possible to use the EGPU for notebook with burned GPU? Mine is Toshiba M840 with Radeon 7670M integrated to the board.
    thanks,
    Andy
  8. Scanner
    Wow it’s been a while since I’ve been in this thread. Remember when I first did this thread one of my 980m cards fried. Both cards were removed and the only thing left was the internal gpu. If your pc has a removable mini PCIE card, or can use the other model you should be fine. You’d be even better with a thunder bolt connection.
  9. hstpctech
    hstpctech Newbie
    Hi Scanner,
    I'm rather late into this eGPU game. Good thing I can still found your post.
    As for my M840, the internal Radeon is fried. I believe the notebook has mini PCIe, although the question is whether I can plug in the eGPU and expect it to kick in right from the POST-UP screen? If I need to install it in Windows first then I'm out of luck here.
