AW17R1 msi 1070 trouble
Discussion in 'Alienware 17 and M17x' started by Hirosake, Feb 8, 2020.
  1. Hirosake
    Hirosake Guest
    Hi Power Rangers. Im also having trouble with a new (to me) msi 1070 card.
    I was trying to flash a few different vbios roms from techpowerup to try and get around this throttle issue, but the last one (Nvidia 86.04.67.00.1E) killed it and I get 8 beeps on POST.
    I have to spi reflash with something else...but.....anyone with experience know why this is throttling? Performance cap reason switched between PWR-VREL-IDLE....I have 330w power brick.
    Thank you :)
      File size:
      23.5 KB
      53
  2. Rengsey R. H. Jr.
    Most likely wrong vbios. I would only recommend MSI vbios. Majority of vbios from other vendor has different power requirement, less or more can hurt the card.
  3. TheReciever
    TheReciever D! For Dragon!
    330w AC adapter doesn't matter much, machine can't accept more than 115w anyways.
  4. Hirosake
    Hirosake Guest
    Thank you gents...I will try a msi rom soon as this spi flasher arrives.
    Yeah I came late to the party with upgrading my Ranger....Im also actively looking for my next laptop....I will keep this as my backup.
  5. Hirosake
    Hirosake Guest
    @Rengsey R. H. Jr.
    I may have killed it already...I got flash to work and flashed msi rom from techpowerup
    But now the card is not seen in BIOS...says not detected in dedicated graphics :(
    sorry to bother...but could you point me to a msi 1070 rom?
    I will try another one
  6. Mr. Fox
    Did you save and chip dump with the original firmware before flashing? If so, try putting it back on.
  7. Hirosake
    Hirosake Guest
    Nope...first read was just garbage. I think I killed it with nvflash
  8. 2CPU
    2CPU Notebook Consultant
    Any luck?
  9. Hirosake
    Hirosake Guest
    Definite maybe. :confused:
    Lets see...while waiting for my spi flasher I was altering the N173HHE-G32 screen, putting new backing material and then...I stuffed up..I broke the edp cable. I couldnt repair it so I ordered a new one and still waiting for it. In mean time i have 60hz lvds panel installed.
    I then got the flasher and worked it all out. It looks like it flashed!!....but...
    I didnt realise the 1070 needs edp to start...wont play with lvds....so I put card into the pc and it wouldnt even show up in BIOS.
    I will know if everything is ok once i have the new edp cable :)
  10. 2CPU
    Oh ok sounds like progress. What VBIOS did you flash? I have a 1070M from a Zotac but never knew what flash was on it. If you let me know the utilities and method I can dump the VBIOS for you.
