AW17R1 hmdi inop and optical drive question
Discussion in 'Alienware 17 and M17x' started by CerberusVI, Dec 1, 2020.
  1. CerberusVI
    CerberusVI Notebook Enthusiast
    So I've been running my upgraded R1 with a 1070 for a while and I love. It does everything I need it to unlike my last bga turd. I have even bought a mini display port to display port adapter and have run my Valve Index off of it no problems.
    But I recently tried to hook my laptop to my tv using the hdmi in/out port and could not get anything to work. In the nvidia driver it would show the 2nd samsung screen but I could not get a display to it. I tried doing the function keys and switching it etc, making it the tv the only display and still nothing. Iirc I purchased the MSI black pcb 1070 and upgrade to the 120hz panel if that makes a difference. I'm running whatever Vbios it came with and verified it's pulling 100+ watts as I read some had 90w limiters?
    My second question is I was messing with my optical drive though I never use it tbh, but I tried inserting an old game to install from the dvd and it caused the system to hang. I forced restart and everytime it initialized the drive to read it would hard lock. I couldn't even get my disk back, so I removed the ODD and manually got my disk back. Which I think I messed up the drive as now it makes a bunch of racket putting a disc in it. I have an external dvd-rw drive and the disc worked just fine in that.
    Can the dvd drive be upgraded to the Blu-ray drive from the m17xr4 for example? It would be nice to have a Blu-ray drive for movies on the go if I was to fix it? I don't really need another hdd bay either as I have 1tb ssd and 1tb hdd in the second slot. I can't see needing more storage at the moment so I won't really look at the optical drive to hdd adapter.
  2. lingenfr
    lingenfr Notebook Geek
    Since none of the knowledgeable folks have answered, I will give it a shot. I have the HL-DT-ST DVDRWBD CA40N and it works fine in my Ranger. I don't play many BDs, I primarily use it for ripping, but it works for either
    Sent from my SM-N975U1 using Tapatalk
  3. lingenfr
    The model I have is HGST HTS721010A9E630
  4. CerberusVI
    Well I figurd out my HDMI In/Out issue. I was missing the Dell Alienware On Screen Display Application. I downloaded it from the Dell website and now that is all working again! I still haven't fixed the optical drive yet though
