AW M15x Throttling Issue Investigation - Stock clocks and overclocked.
Discussion in 'Alienware M15x' started by 5150Joker, Dec 2, 2009.
  1. 5150Joker
    5150Joker Tech|Inferno
    Info no longer relevant. Dell has released a new bios update that resolves it.
  2. The_Moo™
    The_Moo™ Here we go again.....
    you can run OCCT to have it print out in a big chart and the temps will fluctuate along with the speed...theoretically ;)
  3. inap
    inap .........................
    is this a big issue, man just ordered M15x and now I hear this. hopefully not a mainboard issue.:mad:
  4. 5150Joker
    Until others confirm this is happening to their systems, it's not definitive. Unfortunately not a single person has stepped up yet.
  5. Juason
    Juason Notebook Consultant
    I will test mine..when it arrives! :complains: Which CPU do you have again?
    I'll also post some tests using my Kill A Watt power measuring tool. It would give us a better idea of how loaded the AC Adapter really is.
  6. CitizenPanda
    CitizenPanda Notebook Deity NBR Reviewer
    Agreed, run the OCCT PSU test and graph it... see what you get.
  7. 5150Joker
    I ran OCCT PSU but it only shows temperature changes, not frequency throttling. I did however run GPU-Z at the same time and this is what it looked like:
    The spikes are when it hit full stock clocks and the rest was the throttled 3D clocks.
  8. thalanix
    thalanix Notebook Deity
    is the M15x power brick 120W (19V/6.3A)? if it's like the G51J, then AW cut corners on power. the graphics chip requires 75, CPU @ 55, and extra for peripherals (screen etc.) which go well over the 120W with my G51.
    log CPU freq/multi with http://www.cpuid.com/tmonitor.php while having those running. my guess is it will be throttled when the GPU is used and vice versa.
    > http://forum.notebookreview.com/showthread.php?t=436536 says 120W
  9. CitizenPanda
    No, the M15x uses a 150W PSU.
    It probably requires closer to 180W.
  10. 5150Joker
    Hey thalinx, the PSU is rated at 150W. I believe the old area m15x used the 120W adapter. I'm going to do a respawn (factory restore) to rule out any possible software glitch and then run the Tmonitor with the benchmark programs. I'll update this thread once I do.
