Aw 17 R4 - how do you clean the fans?
Discussion in '2015+ Alienware 13 / 15 / 17' started by TechnoWhore, Nov 16, 2016.
  1. TechnoWhore
    TechnoWhore Notebook Evangelist
    Hi guys. Looking to buy this beast in the future and was watching a few vids on the internals of the machine. I noticed it didn't look like you could the remove fans. Can the fans be removed to clean dust from them and the vents?
  2. Divine_Madcat
    Divine_Madcat Notebook Evangelist
    The external bottom plate is easy to remove (7 screws, no warranty tag), and you can used a compressed air can to easily blow it out from there. All of 5 minutes i would guess. However, to remove the fan/heatsink assembly (they are one unit) requires significant disassembly. That said, given that you can blow them out with air directly, there would be no need to go that far...
  3. TechnoWhore
    Thanks for reply. Didn't realise fan and vent were one unit,
  4. Alienware-L_Porras
    That shouldn't be a problem. You can get to the fans and use canned air to clean them. You can dismantle it further, but it'd be pretty much the same result.
