Automatically sync folders with flash drive?
Discussion in 'Windows OS and Software' started by andrewt1187, Nov 11, 2008.
  1. andrewt1187
    andrewt1187 Notebook Consultant
    Is there a program out there to automatically sync certain folders with a flash drive when plugged in.
    IE. I save a bunch of stuff in My Documents. I plug my drive in and the flash drive is automatically updated with the new/changed files.
    Thanks!
  2. vinumsv
    vinumsv MobileFreak™
  3. AndyC812
    AndyC812 Notebook Enthusiast
    Whoa! So there's synch software built into Vista!? Is this in every version or only some versions? I just got a new laptop (HP HDX16t) with Vista Home Premium 64 bit, is it on there?
    Thanks,
    Andy
    HP HDX16t
    Intel Core 2 Duo Processor P8600 (2.4 GHz)
    4GB DDR2 System Memory (2 Dimm) 512MB NVIDIA GeForce 9600M GT
    16.0" High Definition HP Ultra BrightView Infinity Display (1920x1080)
    320GB 5400RPM SATA Hard Drive Webcam + Fingerprint Reader with HP Imprint Finish (Fluid)
    Intel Next-Gen Wireless-N Mini-card (WiFi Link 5100)
    LightScribe SuperMulti 8X DVD+/-RW with Double Layer Support
    Windows Vista Home Premium SP1 (64-bit)
  4. vinumsv
    So It should work in all versions :D
  5. superduty
    superduty Notebook Consultant
    Check out http://allwaysync.com/index.html
    You can also DL as an app which installs on your flashdrive. Nice for those of us who use machines at work with no admin priv.
  6. AndyC812
    OK, I found the Sync Center on my Vista, but when I plug in my flashdrive it recognizes it as a Media Player and wants to sync it only with Windows Media Player. I cannot for the life of me figure out how to convince it otherwise. I have looked at all the Vista help from MS on my machine and online, no help (as usual).
    Any ideas?
  7. X2P
    X2P I♥COOLING | NBR Super Mod
    Do you have office 2k7?
  8. AndyC812
    No, not yet, I use Office 2003. What does that have to do with Sync Center?
  9. Hep!
    Hep! sees beauty in everything
    Office 2007 includes something called Groove which is for syncing.
  10. AndyC812
    Trying this one out. So far so good. Thanks for the tip!
