auto Undervolting
Discussion in 'Gaming (Software and Graphics Cards)' started by Gianlucadbl, Mar 29, 2019.
  1. Gianlucadbl
    Gianlucadbl Notebook Guru
    I had the doubt because even not setting it to on, HWinfo gave me -130mv.
    Are there any contraindications in the IGPU undervolting? if it can lower the temperatures further without altering the performance, I do it.
    I also read that it's appropriate to set at least 2 profiles for laptops, is it really that important?
  2. pete962
    pete962 Notebook Evangelist
    If HWinfo tells you cpu is undervolted, then it is. Once you go to FIVR page, set everything correctly and press OK, it's done.
    The profiles are self explanatory, if you want to use them, fine, if not also fine. One reason you may want to use them is for example much better battery life by limiting turbo and increasing undervolt to maximum, another one maybe good for gaming where turbo is set to maximum or even locked, but less undervolting so computer doesn't crash under full load and high cpu temperature. Since every computer is different and people use their computers differently, there are no strict rules, but rather general guidelines and you need to do your homework experimenting and see what works for you. I have one general profile that I use most of the time, which I don't touch, but when I want to experiment I use other profiles without messing the one I know works well.
  3. Gianlucadbl
    but how is it possible that in both cases, both with turn on and turn off, hw info always marks it as active?
  4. pete962
    Wait for UncleWeb to answer your question, I don't know specific reason for this switch, maybe it just turns settings on that page, like set multiplier? It doesn't affect my undervolting either and it makes sense, undervolting is set and forget kind of a deal, it would make no sense whatsoever to turn it off ever, if set properly. On the other hand other settings like disable turbo, set multiplier etc. you may want to adjust and turn on/off depending on needs, but it's just my guess since my primary use for this program is undervolting and I haven't experimented much with other settings.
