auto Undervolting
Discussion in 'Gaming (Software and Graphics Cards)' started by Gianlucadbl, Mar 29, 2019.
  1. Gianlucadbl
    Gianlucadbl Notebook Guru
    How can I reduce the voltage automatically every time I restart my laptop? with XTU at every reboot it resets
  2. KING19
    KING19 Notebook Deity
  3. thegh0sts
    thegh0sts Notebook Nobel Laureate
  4. Gianlucadbl
  5. Gianlucadbl
  6. KING19
    This should make it easier for you
    hmscott and 0lok like this.
  7. Gianlucadbl
    Thanks mate, it works good
    Inviato dal mio SM-G965F utilizzando Tapatalk
    KING19 likes this.
  8. Gianlucadbl
    Is it possible that by doing a higher undervolting (for example: from -130mv to -150mv) the temperatures increase rather than decrease?
    Why should the undervolting of the GPU also be carried out?
  9. Gianlucadbl
    something that nobody says in tutorials, but on throttlestop after setting everything up you have to press turn on? must the miniature icon be green or red?
    in many videos also, the undervolt of the integrated GPU is also applied to throttlestop, should I do it?
  10. KING19
    The tutorials are not going to tell you everything but yeah you need press turn on so your undervolt settings will be activated.
    You dont have to undervolt the IGPU but if you want to go for it but dont undervolt it the same as the CPU, Set it at -50.8mv
