ATI LCD color adjustment tips...
Discussion in 'LG' started by MWP, Sep 16, 2005.
  1. coriolis
    coriolis Notebook Nobel Laureate
    Where do you adjust it, it could be I'm adjusting it in the wrong place...
    Since contrast only goes up to -40 to 40 here...and nowhere near that 100
  2. qwester
    qwester Notebook Virtuoso
    I am doing it from the advanced options in the display menu (the one you get to from the control panel), I have a "color" tab, not sure if that would disappear/become disabled, when you install the tray tools. As I mentioned before I am using the Omegas but I deselected tray tools on install.
  3. coriolis
    Ooohhh found it LOL!
    Hmmm it looks weird...
  4. AuroraS
    AuroraS Notebook Virtuoso
    It does look a little weird at first, but once you get used to it, it looks quite nice... ;)
  5. coriolis
    After 5~ months of this settings, I can say, I can't go back. My retinas burn when under the old settings. For some reason it reset so I had to dig for this thread!
    Someone sticky this!!
    In the guides even! :D
  6. 4ndr3
    4ndr3 Notebook Geek
    i was in wrong place too... now is good. even in this not too good screen. Great post. Can anyone tell were i can find this type of config for crt monitors? sorry is a little of topic but i need to know how can i config my two crt monitors....
    thx
  7. Sexybeast
    Sexybeast Notebook Consultant
    i tried it, dont like it. i like my lcd super blinding bright.:cool:
  8. EEEECHUTA
    EEEECHUTA Newbie
    These are pretty good settings. Most LCD displays today come set to a very blue color temperature, around 10,000k or so. But most photography and television studios, if I'm not mistaken, use 6500k as a reference point (which refers to a very spcific kind of white).
  9. EEEECHUTA
    EEEECHUTA Newbie
    I should also mention, that if you want to use these settings for video clips, make sure you're not using video overlay mode, because overlay will use still be using the "default" color scheme and it will still be very blue.
    In order to have these warm color schemes applied to videos, you must use a player that supports vmr7/vmr9, like media player classic.
  10. silencejar
    silencejar Notebook Guru
    I agree, this guide should be somewhere that more people can see it...
    I've been using these settings on my z70va for a few weeks and it has helped tremendously with eye strain.
    And I thought it was the tiny text! :D
    Thanks!
