Atheros AR928x Wireless Network Adapter
Discussion in 'Networking and Wireless' started by colorific, Aug 12, 2008.
  1. wlan_man
    wlan_man Notebook Consultant
    Give the modded driver at LV2go a go.
    I had a similar issue at a friends place, no signal in the next room
    With modded driver full 5 bars.
    Beware these atheros drivers are really weird and have different affects on different setups.
  2. TheUndertow
    TheUndertow Notebook Deity
    My Asus G71G-A2 has this card but I can't get it to run in N mode --- anyone else have this problem on a new unit and what can be done to fix it?
  3. wlan_man
    You are running your router in AES and WPA2 ?
    Also your router is set to broadcast in 40Mhz (or 20/40Mhz Auto) ?
  4. TheUndertow
    Not sure - I went with the Belkin + which supposedly should allow for N plus G connectivity. I understood that mixed modes would make the N speeds lower, but it seemed to only broadcast in G.
    I ended up returning the router but would def. get another one if i can figure out whether it's a router setting or the laptop's network card.
