Asus Zenbook UX430UA touchpad problem
Discussion in 'Asus' started by ZombieHero3, Jul 9, 2017.
  1. ZombieHero3
    ZombieHero3 Newbie
    I like this laptop by far but this touch pad keeps annoying me. Sometimes it glitches and cursor moves too fast in unwanted directions for a few seconds. This can repeat after several minutes.
    I mean, for 1k$ machine, srsly?
    Do you think its hardware or software?
    I tried reinstalling Precision TouchPad, didn't help.
  2. legnemakne
    legnemakne Newbie
    Unfortunately, this happens to all metal case laptops from Asus. Return it if you can (and buy another model from another brand).
    Mine is a UX310CA, same problem. But I can't return it because I moved to another country.
    I'm not sure, but it seems to be not software related, but hardware. I tried with Windows 10 and Linux (Ubuntu and Arch), same results.
    I would like to find a solution for that... I wish someone can help us. =\
  3. ZombieHero3
    ZombieHero3 Newbie
    Cursor moves like crazy too?
    I bought this laptop in another country, as far as I know Asus has global warranty. I just wish this was software, behavior is too strange to be hardware - related.
  4. legnemakne
    legnemakne Newbie
    Yeh, moves like crazy... and then, if you leave it alone for about a minute, it backs to normal.
    Then, after a time (could be minutes or hours), here you go again. This happens in Linux, Windows, what ever... no software related.
    So, you bought in another country? Same boat then...
    I guess the warranty will not help us, because I saw some comments in a youtube video of this issue... they said the laptop returned with the same problem after sending it to Asus.
    Maybe it is a design flaw that needs a non conventional solution, I heard something about disassemble it and remove some kind of plastic envelope in the touchpad, but I really don't know.
    I will never buy Asus again, neither laptops or smartphones.
  5. ZombieHero3
    ZombieHero3 Newbie
    Well, this is very sad. From one of me most popular laptop manufacturer. I wanted to buy ux410 but then decided to add some money to buy 430 =_=
    Same here, I think my next laptop will be Dell probably
  6. legnemakne
    legnemakne Newbie
  7. legnemakne
    legnemakne Newbie
    Well... according the support: "you should update drivers".
    I installed Linux again and everything is fine, it still happens but I don't notice so often.
  8. gg007
    gg007 Notebook Enthusiast
    running windows 10... I have the latest drivers... the problem exists. :(
  9. legnemakne
    legnemakne Newbie
    Yeah... there is no solution for that, sadly.
    You should try Linux.
  10. nvnamsh
    nvnamsh Newbie
    I also have the same case with Asus ux410uqk. After many install, update driver. I removed the battery and inserted it again, the touchpad reacted normally. But after a while, it is faulty.
