Asus S17 question about RAM speed
Discussion in 'ASUS Reviews and Owners' Lounges' started by liplenny, Jul 1, 2020.
Tags:
  1. liplenny
    liplenny Newbie
    How can i enable the 3200MHz speed in the BIOS?
    my model display right now 2933MHz
    *Full DDR4-3200 support will be enabled by an automatic BIOS update in July 2020. Older BIOS versions can manually set the memory to 3200MHz, but the July update is recommended for maximum stability.
    there is a Overclock menu in the BIOS with option to Disable Enable, it's can be there?
  2. Wertzius
    Wertzius Notebook Consultant
    It should be there, yes.
