Asus N56VB Power chord/jack problem
Discussion in 'Notebook Cosmetic Modifications and Custom Builds' started by Dietrich1001, Apr 8, 2017.
  1. Dietrich1001
    Dietrich1001 Newbie
    Hey Guys,
    Sorry for inappropriate post but I have a question/problem.
    I have an Asus N56VB that has a charging problem. Whenever I am using its charger it erratically commutes between battery and ac power making usage impossible. I also have an XPS 13 and by using its AC I can use the ASUS without any problems. I went to a guy that checked the tension in the ASUS charger and told me the power is constant so it`s not at fault, blaming the internal ac outlet.
    Do you think it`s an internal outlet problem or a charger problem? I wouldn`t like to buy a new ASUS charger just to have the same problem so I am awaiting your opinions
