Asus N53JQ - Issue with Intel Turbo Boost
Discussion in 'Asus' started by TonyH12, May 3, 2011.
  1. Phistachio
    Phistachio A. Scriabin
    LOL! Nice metaphor :p
    Well, if you don't have that option ( neither do I ), you will need to update your BIOS.
  2. TonyH12
    TonyH12 Notebook Enthusiast
    I was hoping that I would not need to result to that. I don't know much about laptops, but I know that messing around with the BIOS can be a bad thing.
    Anyways, is there a way to check which version BIOS I'm running? Looking at the Asus driver support I notice that there have been 2 updates. One for "China marketing issue" (newest version) and one that is just a firmware change. Phistachio, I just wanna say thanks again for your help. I've been searching for an easy fix everywhere, but I think that I came to realize that this is either a BIOS problem or hardware (very unlikely...). Anyways, I'm gonna call up Asus and ask them which version of BIOS I should use.
  3. Phistachio
    No problemo Tony :D
    Messing around with the BIOS is good and bad : when you know how to do it, it's a piece of cake. When something goes puff... Then yeah, you know :p
    It is very unlikely it is a hardware problem. To check the BIOS version, enter the BIOS, and then, while in the "Main" tab, you will see :
    BIOS Information
    BIOS Vendor - American Megatrends
    Version - N61Jq 212 <- That's the BIOS version ( in my laptop, I think it should be the same with yours, but instead of N61Jq, a N53Jq ).
    Anyway, could you please describe your problem again, I'm kind of lost :eek: :p
    Cheers! :)
    Now, looking at your picture in the OP, I can clearly say that somehow the CPU is at power saving mode, because that's the speed I get when I'm in P4G Battery saving mode...
    I THINK, as a last resource, a PC re-format would help.
    OT : How did your finals go? Did they go well? :)
  4. TonyH12
    Finals went OK. Thank goodness my classes have curves or else I would be doomed.
    So my problem is that my laptop is always running at 930 MHz no matter what I'm running. Basically, I feel as if my laptop is running at an "idle" stage all the time. In the past I saw the clock go to 3000 MHz. I reformatted twice. 1 time with a clean install of a Windows 7 and the second time I reformatted using my backup CD.
  5. kimiraikkonen
    kimiraikkonen Notebook Evangelist
  6. Phistachio
    Mmm... That is weird...
    Perhaps there is some weird bug which fixed the multiplier in the BIOS?
  7. TonyH12
    I downloaded the Intel Boost Monitor and I can see it go up and down, but it never goes beyond a certain point. It moves up and down about a centimeter at times.
