Asus G751 coming with Maxwell GTX 980M and GTX 970M
Discussion in 'ASUS Gaming Notebook Forum' started by Cloudfire, Sep 19, 2014.
  1. 3nDo3mO
    3nDo3mO Notebook Enthusiast
    300 Gb of 455Gb free on SSD (assassins creed unity installed on this drive)
    600Gb of 1tb free on HDD
  2. 3nDo3mO
    I'm sorry, yes the Nvidia drivers and no I didn't run any validation checks. After the Nvidia driver update 347.52 all the optimal settings are low (texture quality,shadow quality and environment quality) and evething else off (SSAO, FXAA) and resolution is 1366x768 and I get the message in my NVIDIA Gefroce experience that "Your system does not meet the minimum requirements for optimal settings in the game. Same with EVOLVE.
  3. pato
    pato Notebook Evangelist
    I would say, revert to the previous driver release. It sounds as if the GPU was not correctly detected/installed.
  4. Support.3@XOTIC PC
    Support.3@XOTIC PC Company Representative
    You can check Nvidia Control Panel to make sure the games are set to High Performance or select the GTX 970M. It may have reset to run of the Intel HD when you updated the drivers.
  5. Meaker@Sager
    Yes try rolling back because it should not impact the installation of games.
  6. 3nDo3mO
    Yep the control panel setting for PhysX was auto so I changed it to GPU. Also rolling back didn't help it had the same optimal settings so I reverted it back to latest drivers.
    Is there anyone else who installed any of the latest games on their G751JT?
  7. Meaker@Sager
    Does the message allow you to continue and play anyway? How is the performance if so?
  8. 3nDo3mO
    It does but getting low frame rates, like 35 to 45 sometimes even lower. The only way I get higher frame rates is if i use the optimal settings.
  9. eleron911
    eleron911 HighSpeedFreak
    Guys, is the 'nvidia not allowing OCing anymore' a real thing? I can't really find any official information about this.
    Resellers, anyone?
  10. BigDRim
    BigDRim Notebook Consultant
