Asus G751 coming with Maxwell GTX 980M and GTX 970M
Discussion in 'ASUS Gaming Notebook Forum' started by Cloudfire, Sep 19, 2014.
  1. eleron911
    eleron911 HighSpeedFreak
    Unfortunately, switching to high performance yielded no difference, still 464.
    What benchmark recommendations do you have for testing the CPU? I'd like to do the same tests as others with the 4710hq and x37 multiplier for comparison.
  2. Adly2010
    Adly2010 Notebook Enthusiast
    Hello
    I just want to ask some questions about G751JT-CH71
    1- How many seconds does boot take (time from pressing power key untill desktop appears) ?
    2- did you try to overlock the cpu to make sure that it has turbo up to 3.5 GHz?
    3- IS sound good and loud ? >> can i watch a movie with 4 friends with loud sound that make us enjoying the movie with a clear and loud sound ?
  3. BigDRim
    BigDRim Notebook Consultant
    1. approx 5 seconds i'd say.
    2. It has turbo boost.
    3. I never use speakers but they seem good enough to me.
  4. Adly2010
    5 seconds with ssd or without ?
  5. x7007
    x7007 Notebook Guru
    Can someone please upload the G751 original OEM drivers folder ? it's like 2.22GB
    Somehow it got deleted and I'm missing some of the drivers.
  6. BigDRim
    With but without it is quite the same.
  7. ZeroX03
    ZeroX03 Notebook Guru
    Has anyone managed to disassemble one of these models? Really curious to see the innards.
  8. hmscott
    x7007, I have been told by some G751 users that C:\eSupport\eDriver folder didn't show up on their laptop, only the C:\eSupport\Manual directory, so it is likely noone can upload them for you, as they don't exist.
    Asus has drivers/apps for download for the G751's here at a jumping off point for all 3 models:
    G751 Support / Download Areas - Newest - has all 3 G751 models
    http://www.asus.com/Search/?SearchKey=g751
    Asus has a bad habit of not filling out and keeping current the drivers for their hardware, BIOS's are updated in each model area, but new drivers tend to be added to new products with the same hardware, not the previous products
    The G750/G751 use similar hardware/chipsets/peripherals so you can pull the drivers from your model area, and then all the other model areas that have newer drivers for your same hardware.
    There are some categories where you need to be specific about the exact name of the driver - like Qualcomm / Athereos parts - you may download a driver that looks right, but refuses to install - you got the wrong one.
    Use Features and Programs control panel and look carefully at the name and the Version - the Version is the best clue as each model of part follows a different series - except for those that share the same driver package... you will figure it out.
    Asus also has central areas for drivers/app support that are supposed to get updated whenever a new product comes out with that hardware - they are good places to scan for newer drivers.
    Notebook Audio - for G751 => Realtek driver package Version V6.0.1.7335
    ASUSTeK Computer Inc. -Support- Drivers and Download Audio
    Notebook Bluetooth drivers
    ASUSTeK Computer Inc. -Support- Drivers and Download Bluetooth
    Notebook WLAN drivers (no Intel)
    ASUSTeK Computer Inc. -Support- Drivers and Download WLAN
    Notebook LAN drivers
    ASUSTeK Computer Inc. -Support- Drivers and Download LAN
    KBFilter driver
    ASUSTeK Computer Inc. -Support- Drivers and Download KBFilter
    Asus Backtracker for Windows 8.1
    ASUSTeK Computer Inc. -Support- Drivers and Download Backtracker
    Asus SmartGesture
    ASUSTeK Computer Inc. -Support- Drivers and Download ASUS Smart Gesture
    Asus Touchpad
    ASUSTeK Computer Inc. -Support- Drivers and Download Touchpad
    Asus ATK Package
    ASUSTeK Computer Inc. -Support- Drivers and Download ATK Package
    Asus GPU Tweak for Graphics Cards, currently at release v2.7.1.8 for the G750JW/JX/JH and G751JT/JY and other non-Optimus laptops
    ASUSTeK Computer Inc. -Support- Drivers and Download ASUS GPU Tweak for Graphics cards
    Asus GPU Tweak for Laptops, currently at release v1.0.9 for the G750JS/JM/JZ and other new ROG laptops with Optimus, G751JM(?)
    ASUSTeK Computer Inc. -Support- Drivers and Download ASUS GPU Tweak for Laptops
    Here are the Asus posted VGA drivers, it's better to get the Newest from Nvidia.
    ASUSTeK Computer Inc. -Support- Drivers and Download VGA
    Nvidia Drivers direct from Nvidia
    Drivers | GeForce
    Asus stopped updating their Intel INF Update support area, so go directly to Intel to get the latest the 9 series is new enough for G751.
    https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&FamilyId=42&ProductID=816&ProdId=816
    You can also use the Intel Driver Update Utility to find the latest Intel drivers
    http://www.intel.com/p/en_US/support/detect
    And, that list should get you everything you need, including newer versions than you laptop ship with originally.
    Have fun :)
    Update: While researching the G751 download areas, I found that Asus has 3 seperate Web Design / Layouts, each progressively with newer/more packages. I edited down this post and made a new one with all 3 listed here: http://rog.asus.com/forum/showthread.php?55572-Asus-G751-Support-Download-areas
    NeoteriX, eleron911 and UltimaXemnas like this.
  9. Adly2010
    5 seconds from pressing power until desktop appears or until windows starts ?
  10. d0r1n
    d0r1n Notebook Guru
    from pressing to desktop,thats how is done.....mine takes 8 sec to desktop and other 2 sec to all programs tot start,so a total of 10 sec
