[ASUS G73sw] LAN not working after BIOS flash
Discussion in 'Networking and Wireless' started by FCU4ever, Mar 19, 2019.
  1. FCU4ever
    FCU4ever Notebook Enthusiast
    Hello,
    I’ve flashed the BIOS of my Asus G73sw laptop to enable Intel AES-IN. The flashing process was succesfull be done, but after reboot my LAN port stopped working. The LAN card also not showing in ‘Device Manager’. To resolve the problem I tried to re-installing the LAN driver with no luck. During the install process I’ve get the following warning: ‘The Realtek Network Controller was not found. If Deep Sleep Mode is enabled Please Plug the Cable’. I thought the LAN Card died so I bought a new one. After receiving the new LAN Card I installed it to my laptop. Unfortunately this doesn’t resolve the problem. Still no working LAN port and the same error during the driver installation. After some research on the internet I think that the BIOS flash has override the MAC address of my LAN Card. To change the MAC address of my LAN Card to a correct one I found this tutorial: http://www.ocworkbench.com/2002/ecs/k7s5aguide/LAN MAC ADDRESS FIX GUIDE.htm
    The problem is that I can’t found the original MAC Adress of my LAN CARD on the sticker of the LAN Card. Can someone help me to find out what the MAC Adress of my LAN Card is so I can change the overridden address to the correct one. See the pictures below for my LAN Card.
  2. senso
    senso Notebook Deity
    Your cable looks kinda iffy, is it well connected?
    What BIOS did you flash?
    From Asus site, or from elsewhere?
    Does the LAN adapter shows up in the Device Manager(Win+X then Device Manager).
  3. FCU4ever
    Tried a new cable and new LAN card, same problem.
    I used the BIOS from this thread: http://forum.notebookreview.com/threads/unofficial-bios-to-fix-throttling-for-g73sw.631869/
    LAN adapter also not shows up in Device Manager. The USB port that is also on the LAN card is working well..... that is the strange part.
