Asus G60VX - RBBX05 Low Sound Issue Solved!!!
Discussion in 'ASUS Gaming Notebook Forum' started by jaktharkhan, Jan 19, 2010.
  1. jaktharkhan
    jaktharkhan Newbie
    I finally solved the low sound issue on Asus G60VX - RBBX05!!!!! . Now this laptop is perfect! Solution below will probably work for other laptops that are running Windows Vista or Windows 7 and having this same issue. The problem is regardless of raising the volume to the max the sound is still too low.
    Here is how to fix it.
    1. First you need to go into the bios and make sure the sound volume is at its highest.
    2. Open Control panel and choose ‘Hardware and Sound’
    3. Then choose ‘Manage audio devices’
    4. On the playback tab make sure speakers is selected.
    5. Click on properties.
    6. Click on ‘Enhancements’ Tab
    7. Check the Box ‘Loudness Equalization.’
    Your sound is now very high!!!. Amazing how easy that was! Now you can enjoy your laptop.
  2. Derek1387
    Derek1387 Notebook Guru
    yup. it works ;)
    Thanks for the info!
  3. carajean
    carajean Notebook Geek
    I dont see the enhancement tab on my windows 7. But i do only have the g51vs from BB.
  4. E.B.E.
    E.B.E. NBR Procrastinator
    Moved to main ASUS forum.
  5. dizzyegg
    dizzyegg Notebook Consultant
    Thanks
    10char
  6. be77solo
    be77solo pc's and planes
    This is wierd, mine is actually quieter with that boxed checked than without, but not by much... this is with playing music. Also, using a G51 if that matters
  7. dizzyegg
    Mine also goes a little quieter.
  8. joe1985
    joe1985 Newbie
    Your first suggestion doesn't change the actual output of the speakers it controls the sound of the file that is played on POST. Second, I think everyone has already tried the loudness equalization and it doesn't make much of a difference.
    Has anyone actually resolved this issue?
  9. Eclypse3D
    Eclypse3D Notebook Geek
    You also may want to check under enchancements the equalizer option check select Powerful. It basically increases all the audio bands across the board evenly. It does increase the volume on the laptop.
    I had the G72 and those speakers where louder but I did the same thing on that unit to increase the sound as well. Keep in mind though that if you change the eq settings like this to change them back to none or another setting if you use an external receiver or speakers or your sound output will be too high and thus also possibly bad sounding. =)
  10. Dragauss
    Dragauss Notebook Geek
    FYI, all this really does is make both speakers produce the same volume. This is bad for anything directional. Thus any sound that requires separate channels will have it produced from both speakers. For example, in games you can't distinguish gunfire from the right as it will be leveled with the left side. So in essence you get a surround effect where you hear gunfire from both sides.
    This is useful for getting the maximum volume from a single source like someone speaking. But, personally would rather have it un-checked and raise the equalizers higher to preserve separate channels.
    Sharkee likes this.
