Asus G1S Volume Control?!
Discussion in 'Asus' started by YJzoneDOTnet, Jun 26, 2007.
  1. YJzoneDOTnet
    YJzoneDOTnet Notebook Enthusiast
    I just received my new G1S but there is one issue which I just can't believe Asus didn't get right:
    The volume keys don't work.
    If you press Fn+F11 or Fn+F12 to either increase or decrease volume as stated in the manual, it simply doesn't work.
    It does work on XP though...oddly enough, Asus hasn't seem to updated the driver for Vista yet.
    Is there any way to regulate volume using a hotkey? Like a program, maybe.
    I searched and many of them only work on XP. Anyone for Vista?
    Thanks
  2. E.B.E.
    E.B.E. NBR Procrastinator
    Are the other hotkeys working? The brightness up/down, lcd on/off, standby etc.
    If not, you might have a problem with the ATK driver/utility.
    I'm asking because I'm pretty sure other people have not complained about this. And they would've for sure if it hadn't worked.
  3. ktang
    ktang Notebook Consultant
    mine work fine, maybe you uninstalled some programs you needed?
  4. YJzoneDOTnet
    Yes, the others are working....strange. Do the volume keys work on your vista?
  5. YJzoneDOTnet
    OK, checked up and I have ATK Generic Driver & ATK Media Installed.
    on Asus's website, there is the utility called 'keyboard device filter utility'...
    Which I installed but haven't got a clue what it actually does.
    Oh, and Power4Gear doesn't seem to work either on mine, I installed it from Asus's website but it when I press the button on my laptop, it does nothing...
    Help..
  6. E.B.E.
    Try reinstalling the ATK drivers and utility.
    Edit: Also, how did you install Vista? Did you try to do it using the recovery DVD provided with the computer? I would suggest that if you did not; that should provide a working driver setup.
  7. YJzoneDOTnet
    No, I just installed it from my own Vista...
    I did reinstall ATK driver and media but it still doesn't work...
    Any suggestions?
  8. E.B.E.
    Try the recovery DVD (if youre willing to do so). You might have done something wrong during the driver installation.
  9. YJzoneDOTnet
    Ok, I have used the support and installed this so called 'ATK Hotkey' utility and volume control finally works! thanks!
    But..
    I still have a few issues left with this laptop...
    1) Power4Gear button doesn't work even though I have installed it...does it work on yours?
    2) What is this e-mail check utility? Apparently it is used to blink the LED in case a mail arrive but does it work with Windows live messenger?
    3) How can you make the media button on the front to launch WMP instead of Media center (I tried setting WMP to default in vista but it refuses to do so)?
    4) Is this Asus Splendid utility really worth installing? I installed it but pressing Fn+C does nothing...(which according to the manual,cycles through the different modes).
    If the above issues are solved, I would be a happy G1S owner...:)
  10. howardpm
    howardpm Notebook Evangelist
    You sure your not confusing the keys not working to just very low volume? I returned mine because the volume at max was so low it sounded like a whisper.
