Asus F8VA Montevina Mobile Platform review
Discussion in 'ASUS Reviews and Owners' Lounges' started by GenTechPC, Jul 15, 2008.
  1. reignofdragons
    reignofdragons Notebook Enthusiast
    if your 3dmark06 is hanging like mine did, there is a fix for the problem, or at least it fixed it for me. You can try googling it, if not, i can upload it for you.
  2. Ben-
    Ben- Notebook Guru
  3. cfalzone
    cfalzone Newbie
    Does anyone have the actual drivers? I don't have access to the driver DVD so I'm without bluetooth, chipset, and a lot of other things right now. Or is there some update tool that I can use?
    Thanks a lot
  4. E.B.E.
    E.B.E. NBR Procrastinator
    Get the drivers from support.asus.com. They should have all the drivers there. Download may be a bit slow, so be patient. :)
  5. indelibo
    indelibo Newbie
    Has anyone figured a way to remap the FN key? The FN is placed where the Ctrl key should be. I've tried a few programs but they cannot identify the FN key.
  6. catbits
    catbits Notebook Enthusiast
    I'm looking into installing the webcam driver for WinXP... then one on the driver disc doesn't work. Anyone possible know what driver to use?
  7. Satvic
    Satvic Newbie
    on c1 try camera driver D-max GD-5a31 for XP .. v6.21.20.004.
  8. Satvic
    Satvic Newbie
    Howdi all,
    After downgrading to XP it's having problems with standby/resume. If it goes into standby, the screen goes blank, lights stay on .. fan spinning ... it wont come back. only remedy is hard reset. All drivers are appearing to work ok.
    Does anybody has this problem? thanx
  9. E.B.E.
    Do you have the ATK drivers properly installed?
  10. Glock24
    Glock24 Notebook Geek
    I just ordered a F8Va-B1, and since it seems the battery doesn't last long enough I would like to buy an additional battery. Can anyone plase provide me with the battery code or p/n?
    Thank you.
