Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. sc00terx
    sc00terx Notebook Enthusiast
    Hi
    i did try and use my xp cd but its giveing me error`s when it gets half way in my updated xp sp3 works fine
    but when i get it on the acer the hd sound is !
    is there not a driver i can use with sp3 as this would fix this for me
    sc00terx
  2. sc00terx
    Update
    i have just used Realtek HD Audio Drivers v1.92 for XP and Vista
    works ok so far
    sc00terx
  3. ATG
    ATG 2x4 Super Moderator
    Dude, Realtek has new driver, R1.94, just to let you know if you have issues with sound or with a game or something..
  4. bigozone
    bigozone JellyRoll touring now
    glad to hear you finally got it working.....
    now that the sound works... you can update drivers w/ no fears
    later,
    bigO
  5. jc55
    jc55 Notebook Consultant
    My stock 5315 runs 62 C 100 % loaded, use the Windows Experience Index
    update to test it. Seems hotter since I uped the bios from 1.17.
    Should've checked before I uped it to 1.34.
    Anybody tested before and after ?
    James
  6. bigozone
    you might consider a T5450 CPU upgrade
    better battery life,
    less heat,,
    and more CPU power..
    also 2 gig of RAM is a must... especially w/ vista
    later,
    bigO
  7. jc55
    bigO, what's your processor & memory score in Windows Experience Index ?
    Thanks for the info !
    James
  8. bigozone
    i'll have to check my mother's 5315,, cause i UPGRADED to XP Pro as soon as i found all the drivers,,,
    but the memory went up a little,, and the CPU even more,, graphics gained 0.1,,, i'll try to get those #s tomorrow
    later,
    bigO
    LONG LIVE XP Pro
  9. hoggie
    hoggie old boy
    ello mate. all going well i see. nice thread.
    ive had enough of doctors telling me what to do so i'm back:D
    tests over im mad:D
  10. ATG
    Sorry, this is not exactly my thing, but I can assure you WEI is NOT the perfect way to measure performance...
