Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. stevenkelby
    stevenkelby Notebook Consultant
    Nice one!
    How about fan speed control, what are people using for these? My fan is cycling on to high more than it used to, How can I keep it on low or medium under light load? Any good programs people have had success with?
  2. bigozone
    bigozone JellyRoll touring now
    i have yet to find a good one or any that actually control the fan on this model...
    which BIOS are you using??? i've noticed that newer bios releases seem to activate the fan more often
    but i'm about to switch back to version 1.34 despite the COLD BOOT problems,,, because i'm having the sond problems so many people complain about with the 5720...
    if that BIOS is better w/ the fan i'll post
    later,
    bigO
  3. stevenkelby
    Bummer.
    Cool, I might try some others. Currently 1.33.
  4. Cin'
    Cin' Anathema
    This is really helpful info ;) :)
  5. bigozone
    thanks for the support!!!;) :)
    much appreciated,,
    bigO
  6. jc55
    jc55 Notebook Consultant
    So does the T8300 work ?
    I suppose 2 gig chips work, but do they work in pairs in dual channel mode ?
    The reason I haven't tried 2 gig chips is cpuz says 2048 max, doesn't say
    per socket or total.
    James
  7. roddy
    roddy Newbie
    big o
    what do you mean?
    is it the sound... cuzz I have a 5315-2875 and the when i play a video the sound makes my ears bleed
    i have install dif. ver of vista and still
    this is the only thing stopping me to up grade the cpu
    i have look for new speakers and had no luck
  8. jc55
    My 5315-2153 has very low volume, sound is okay just not loud.
    Must be a chip problem in these things or funky drivers.
    James
  9. bigozone
  10. bigozone
    T8300 is not verified... yet,,, but should work
