Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. bigozone
    bigozone JellyRoll touring now
    any of the different colored sockets should be fine without any modification
    later,
    bigO
  2. sc00terx
    sc00terx Notebook Enthusiast
    thanks
    just because it was not the same as the pink/pur one i did think it would need a mod like the rest of them have had but saved me some work :)
    sc00terx
  3. lacky75
    lacky75 Notebook Enthusiast
    next challenge is iv heard poeple installing 4gb ram again cant see why this isnt doable, but can anyone tell me if its been done before i start hassling my local parts supplier. thanx
  4. bigozone
    what OS??
    XP and VISTA 32 bit can only address about 3gigs of memory,,, you might get 4gigs to boot and work,,, just know up front that you will never be able to access all 4 gigs,,,, and some Acers have reported not booting w/ 2X 2gig
    but work fine w/ 3 gigs
    later,
    bigO
  5. lacky75
    iv got vista premium 64bit installed. at least the os wont be a limiter in terms of using 4 gb's and ill need to check but im sure i'v seen a few other i965 based laptops come equiped with 4gb's standard however as u say this may be an acer problem only accepting 2x1gb dimms
  6. jc55
    jc55 Notebook Consultant
    "XP and VISTA 32 bit can only address about 3gigs of memory,,, you might get 4gigs to boot and work,,, just know up front that you will never be able to access all 4 gigs,,,, and some Acers have reported not booting w/ 2X 2gig
    but work fine w/ 3 gigs "
    So are you talking only 5315's or all acers ?
    Pardon my ignorance, was thinking of using one 2 gig stick and one stock 512mb chip. Will it work that way in a 5315 ?
    Thanks, James
  7. bigozone
    that config should work fine,,,
    but some models of acers fail to boot w/ 4 gigs of ram.. even though they claim to support it
  8. mooler
    mooler Notebook Consultant
    I upgraded to a T5450 a few days ago. I was getting Idle temps under 20C now i cant get below 45C. I havent changed anything besides bios version. Any ideas on why this is? I flashed down to the 1.33 Bios because i was having the cold boot problem. Could this be related?
    EDIT
    I just flashed back to 1.34 and RMClock is now reporting temps of 26.6C on startup - 3 mins ago before i flashed it was reporting 50C on startup and idle. Any take?
  9. bigozone
    BIOS 1.34 has those 2 issues
    COLD BOOT ISSUES
    and
    Thermal sensors are mis-read by the BIOS
    the temps are the same... just being correctly reported now!!
    good to see you are awake!
  10. mooler
    Yes I am awake - barely
    So 1.33 reports temps correctly or does 1.34
