Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. mts915
    mts915 Newbie
    Posted by: who can check?
    My GL960 and 5 GB of memory:
    ZY
    I tried to encroach on 6. I did not overcome. 4 + 2 - black screen. 2 + 4 - the laptop starts up, you can go into the BIOS, but the installed Win7_64 hangs up and does not boot. The Win7 installer freezes on the "Starting Windows" screen. What is interesting, but if you install Vin7_32 with less memory, and then add up to 6 GB, then the system boots and works normally. AIDA64 shows all 6 gig, but Windows uses, of course, only 3. Matter of course, left 5 and set Vin7_64
    http://acerfans.ru/forum/topic_1707/209[/QUOTE]
    In the first slot 1, in the second - 4. On the contrary, does not want a black screen.
  2. hoggie
    hoggie old boy
    [​IMG][/QUOTE]
    I will have too get back in the game on here... popped in to see if any of the old team was still about.. give me a couple days to get going again :)
  3. Epictrolloleante
    Epictrolloleante Newbie
    I had an Acer Aspire 5320 ,and i upgraded its Celeron m530 to a C2D T8300 but i couldn't Enable VT with stock the BIOS.
    So i had to use a mod BIOS to enable it with the following steps:
    1.-Download last version of the official BIOS (V1.45 ) from https://www.acer.com/ac/en/US/content/support
    2.-After that unzip the file BIOS_V1.45.ZIP and then run BIOS_V1.45.exe, it will uncompress the files of the .exe
    3.-Replace the file "CL50145A.fd" ,with the file "icl50_1.45_black_edition_40.fd" from this link https://mega.nz/#F!iJ5FwAoR!PqYOcbC_r9dciJ5sut6AfA
    4.-Then, execute InsydeFlash.exe as Administrator and flash the BIOS.
    The original post said the bios may be compatible with the Aspire 5315, Aspire 5320, Aspire 5715Z, Aspire 5720, Aspire 7320, eMachines E510 but I'm not sure if works with all those laptops, i just flashed it on my aspire 5320.
    Do it by your own risk ,Im not responsible if you damage your Laptop, but at least that worked for my Aspire 5320..
    I hope this can help you guys
  4. bizzybody
    bizzybody Notebook Guru
    Didn't Acer's Europe site have version 1.49 for the BIOS? I know when I had my 5315 and upgraded it to a Core 2 Duo I found a newer BIOS on the EU site.
  5. Epictrolloleante
    I guess not, i couldnt find anything about that version of the bios.
  6. IceJazz
    IceJazz Newbie
    Upgrade ACER 5315. Bios flashed v1.45 (mod). The processor put the Intel Core 2 Duo T9300, initially there was a NANYA 1Gb DDR2 667 memory bar, added a 2Gb DDR2 667 HYNIX HYMP125S64CP8-Y5-C memory bar, it became 3Gb. I changed the hard drive to SSD and rolled up windows 10 LTSB 32x bit. The laptop came to life, just do not know. Only began to strain the low speed of Wi-Fi. I ordered the AzureWave AW-CB161H board and a metal adapter to increase the size, the drivers picked up with an automatic machine. At 2.4 GHz, the real speed is 80-90 megabits on the local network. I see 5 GHz networks, but I’m neighboring, I can't check the speed, 2.4 GHz router. Plus, Bluetooth appeared, I connected wireless headphones and a speaker. He took everything on Ali, who can come in handy.
