Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. dtssyst
    dtssyst Newbie
    First and foremost... I would like to thank all that have contributed to this thread. Your information has helped a lot.
    My mom passed away just over a year ago. We have her laptop (Acer Aspire 5315-2326) and was not sure what to do with it.
    I can build a PC from parts but never tinkered on a laptop. Until now that is.
    First thing was upgrade the firmware to 1.45.
    I ordered two 2 gig crucial ram chips off of ebay for under ten dollars shipped. Tried to get 4 gig to work but no luck. It had two 1 gig chips so I took one out and put one of the 2 gig chips in. Success!!! 3 gigs of ram.
    Upgraded to a Core 2 Duo T7700 processor for just under five dollars shipped from an ebay seller.
    Had a crucial m4 128 gig SSD drive laying around so in it went. This gave the best overall performance increase.
    Upgraded the internal wi-fi card to Intel Centrino Wireless-N 1000. Hindsight says that this was a poor upgrade. Purchased it for a few cents so no big loss.
    Ordered the USB 3.0 wi-fi adapter 1200Mbps dual band 802.11 ac from Amazon. A LOT BETTER!!!
    2 Port USB 3.0 54mm Express Card NEC Chipset Adapter Converter Card installed. Now it has USB 3.0!
    Lastly, the operating system is now Windows 10 pro.
    It is now a great laptop that I can use for odd things. Example: our upcoming vacation. I can use the USB 3.0 ports to backup photos from our DSLR camera to external hard drives.
    Thanks again for everyone's help.
    ellalan and triturbo like this.
  2. Ironcap
    Ironcap Newbie
    Hi folk. Thanks everyone for help.
    Just found this laptop (Acer 5315-2803) in garbage room and it is fully working. Just slowly becuase of Celeron 540.
    Found in drawer 2x2GB ram modules. 4GB - is not working. 3GB is working but you have to play with memory slots (as it was mentioned somewhere here).
    Ordered Core 2 Duo T7500 on ebay for 5 canadian dollars I guess.
    Bought for 20 cad msata 120GB for cheap with mSATA to SATA adaptor.
    It will be still capable for office things etc.
    Cheers!
    plumtreed and ellalan like this.
  3. plumtreed
    plumtreed Newbie
    It sounds like you are making great headway with your 5315, with the CPU upgrade you should see a huge difference........keep us informed on progress. Wouldn't the 4GB work on a 64bit system?
    Look fwd to hearing about your progress
  4. Ironcap
    Ironcap Newbie
    BIOS shows 4GB of RAM.
    But when I try load OS - BSOD.
    When I try to install new OS - BSOD.
    Which is weird. Normally if BIOS shows that it means everything is fine.
    I don't know, may be it will be fixed if I program the latest BIOS firmware but not sure. Somewhere in this thread I saw that 4GB doesn't work...
    3GB is already good enough anyway.
  5. plumtreed
    plumtreed Newbie
    Oops, sorry things aren't working out but you seem very close to success. I guess the first thing to check is your version of Windows, if 32bit or 64bit........also if your 5315 is capable of 64bit.
    You could try running with only 2GB ram......see if that works and also make sure fan is plugged in and working.
    .....and what bios is running?
  6. Ironcap
    Ironcap Newbie
    I was trying to install 64-bit Windows 7, got BSOD.
    will check BIOS version later
  7. plumtreed
    plumtreed Newbie
    I don't use Windows on my 5315 so I can't tell you how to check.....but not all 5315s are capable of using 64bit......google a howto to check if your machine is 32bit only......can't run 64bit on a 32bit only machine.
  8. Litigio
    Litigio Newbie
    Grabbed a used 5315 for USD 30 and upgraded to a T8300, 3GB RAM, 120GB SSD, USB3.0 ExpressCard and WLAN ac USB-Stick running Windows 10.
    Also have another 160GB HDD running with Triple-Boot: Windows 7 Starter (x86), Windows XP Professional SP3 and Ubuntu 16.04. (x64). USB 3.0 & WLAN ac will only run in Win7 and 10, no support for both in Linux.
    BIOS is 1.45, did not experiment with a modded one.
    Amazing DIY-project to keep an old device alive, upgradability is nice.
  9. bizzybody
    bizzybody Notebook Guru
    Is that the latest BIOS from Acer Europe? They never put the newest for this model on the USA site.
  10. Litigio
    Litigio Newbie
