Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. Davidwall
    Davidwall Notebook Enthusiast
    I bought 3 of the USB 3.0 Express cards but ended up not using them - they were the usual push in push out type & whenever you plugged IN a usb cable/device then the card would UN plug itself - really annoying (to me anyway).
  2. cheery60771
    cheery60771 Newbie
    I have a 5315-2698 and have an Intel AC-Bluetooth card installed for wifi. The Bluetooth works, just only after you pop the pc out of sleep mode.
    Sent from my SM-G930V using Tapatalk
  3. Ravenholdt
    Ravenholdt Newbie
    Hi, i have read a lot of this thread (thx) for a aspire 5315
    (Celeron CPU 550 @ 2GHz, 2GB RAM and 965 express chipset)
    I have successfully flash the BIOS to v1.45 (acer website) for a T8300 "SLAPA" upgrade
    All is ok and when the computer restart, he smile to me...
    With a black screen (no BIOS screen) just the fan, led and hdd work.
    When i roll back with the old CPU, the PC boot fine.
    So i don't understand if this CPU are dead, not compatible or what i'm doing wrong ?
    Thanks for your help/support
  4. ellalan
    ellalan Notebook Deity
    Since your laptop came with a Merom core CPU, Penryn CPU won't work or it could be a faulty CPU, I would suggest you to get a faster Merom CPU from the link below.
    http://www.cpu-upgrade.com/CPUs/Intel/Celeron_M/550_(Socket_P).html
  5. Ravenholdt
    Ravenholdt Newbie
    i understand now you help me a lot thanks for your link
  6. ellalan
    You are welcome.
  7. Darklord Scotty
    Darklord Scotty Newbie
    A Penryn will definitely work. I am running a T9300 SLAYY CPU... this forum has lots of people who are also running Penryns in their 5315s!
    Scott
  8. Epictrolloleante
    Epictrolloleante Newbie
    I have an old acer aspire 5320 , it had a one core celeron, and i bougth an core 2 duo T8300 and works great, but there isn't any option in the bios for enable VT ,and i really need it because android emulator doesn't works without VT and I need to use it in android studio in my school.
    How can i enable the VT in my laptop?I need help , because I don't know how to flash/ mod bioses , [​IMG]
    Can someone help me?
  9. Darklord Scotty
    Don’t think it’s possible unless you want to try and mod your BIOS. That would be pretty dangerous and would have a high chance of failure. Have a look on Google a few people have written about modding the Acer BIOS to enable VT.
  10. darnok44
    darnok44 Notebook Consultant
    It looks like motherboard used in Aspire 5320 is basically that's same like in 5315, 5715 and 5720, at least is that what schematics suggest, so it's just the matter of finding modded bios for 5315 or 5720 cos those are much more popular models/versions of your laptop.
    Here You have one (download this file: icl50_1.45_black_edition_40.fd) It's bios from this thread on this forum:http://forum.notebookreview.com/thr...-and-discussion-was-x920g-vs-9600m-gt.575866/
    And the folder for download:
    :https://mega.nz/#F!iJ5FwAoR!PqYOcbC_r9dciJ5sut6AfA
