Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. Burcin Karabacak
    Burcin Karabacak Newbie
    hi eveyone
    i wil upgrade my 5315 with T9300 and 3gb and 1tb hdd. will get any problem with cpu or other ?
    my bios v1.45
    thank you
  2. HermannnTheGerman
    HermannnTheGerman Notebook Guru
    Based on my experience, I believe your upgrade configuration should work without problems. Use thermal compound otherwise the cooling system might not work as expected. While you are at it, clean any dust of the fan and the fins of the heat spreader.
  3. Burcin Karabacak
    i didnt buy cpu yet i want to ask one thing ?
    is the T8300 enough or T9300 is good ?
    T8300 in our country i can find 39 Turkish Liras
    T9300 in our country i can find 100 Turkish Liras
    which one will i choose ?
    thank you
  4. HermannnTheGerman
    I'd choose the T8300 as it has the better cost-benefit ratio in my opinion. Then I only have the T8100.
    Burcin Karabacak likes this.
  5. ATG
    ATG 2x4 Super Moderator
    I'd say get the T8300. IMO T9300 should work but you might get heat troubles, T9xxx are known to run significantly hotter than T8xxx
  6. Burcin Karabacak
    i upgraded succesfully my 5315 with T8300.
    next i will upgrade 60gb ssd + 1tb hdd(in dvdrw)
    i love this book :)
    thank you everyone
  7. Pvt. Snafu
    Pvt. Snafu Notebook Enthusiast
    Hey...Here's what I want to know. Can One bolt a motherboard OTHER than an ICL50 (with the Intel GM960/965 Chipset) onto the bottom of the palmrest of the 5315/5520...I mean an UPGRADE (for a possible chipset upgrade) not swap Intel for AMD....like put a NEW MODEL Motherboard into the 5315/5520 case? ICL 50 boards are over 10 years old. What can we put up there NOW?
  8. masterlink2002
    masterlink2002 Notebook Consultant
    sadly i have this running on bios 1.35 with t7250. excited to put ssd in this thing its my blu ray player
  9. Darklord Scotty
    Darklord Scotty Newbie
    Hello.
    I have been keeping an eye on this thread for years and years. Our Acer 5315 refuses to die. I upgraded it firstly to a T8100 + 3GB + SSD + 802.11N card.
    Today I have upgraded it for the last time to the T9300. The CPU is working well on Windows 10. The clock multiplier is working correctly. Temperature is idling at around 45-50 degrees Celsius. Max temperature at full load seems to be around 67 degrees. I used some pretty cheap thermal paste so there is probably some wriggle room for improvement.
    It is incredible the longevity of this machine. Its an 8 year old computer that was pretty ordinary when it was new. It has run Windows XP, Vista, 7, 8, 8.1 and now Windows 10!
    I will keep an eye on things and let you know about the stability in a few weeks.
    Scotty!
  10. cheery60771
    cheery60771 Newbie
    Just did an upgrade using a T9300 on my 5315-2698. It is running much cooler than the T7300 I had originally upgraded to. I did a repair for someone recently on a modern HP laptop and this 5315 was still faster than the cheap Celeron in it in everything but graphics.
