Aspire 5315 CPU Step-by-Step Upgrade Guide
Discussion in 'Acer' started by bigozone, May 20, 2008.
  1. albva
    albva Newbie
    Hello i was reading this post and other related but i have a lot of doubts.
    I have an Acer 5315. Intel Celeron 530, Chipset Mobile Intel GL960 Express, 1Gb DDR2 667MHz. Windows Vista Home Basic. Bios version is 1.19v.
    I’ll buy 1Gb Kingston DDR2 667 so as to have 2Gb.
    Searching information I have found this forum and now I have some doubts:
    1) Differences between GL960 and GM965. I read more about 965 and I don’t know if GL960 can support same processors .
    2) Everest said that my RAM’s laptop is running to 533 MHz, if I upgrade to the latest version of Bios can run to 667 MHz or 800 MHz?
    3) I don’t understand the information of this forum about which processor can I buy to upgrade my laptop. My knowledge about this processors is 0.
    4) My socket put mPGA 478MN and is purple, I don’t understand if this one is N or P, I don’t know how can I identify a valid processor in Processor Compatibility Guide
    Thanks for all.
  2. ATG
    ATG 2x4 Super Moderator
    1. The difference apply mainly to the IGP(integrated graphic card) and supported RAM limit, not the CPUs.
    2. 667Mhz RAM is what Santa Rosa chipset supports max(GL960/GM965/PM965)
    3. You can upgrade to any Merom/Penryn socket P FSB 800Mhz. You can't upgrade to the new Montevina CPUs.
    4. All 5315 should have socket P..as far as I know..
  3. albva
    albva Newbie
    Thanks for your fast answer, but if i upgrade my laptop with an 800 MHz processor this one works to 800 MHZ? or works to 667?
  4. ATG
    The CPU will work at FSB 800MHz(if the CPU is actually FSB 800Mhz) but the RAM will work at 667Mhz(if the RAM actually support it). Santa Rosa chipset has 800Mhz FSB limit and 667Mhz RAM limit.
  5. groggx
    groggx Notebook Enthusiast
    Yup, Already running with 2 GB of Ram. Planning to Upgrade to 3GB of ram after I upgrade the wifes 5315 to a dual core. Thanks for the great info.
  6. ATG
  7. king4eva
    king4eva Newbie
    i have a Acer Aspire 5315-201G08Mi with a 550 celeron cpu 2.00ghz, which cpu can i uprade to ?
    thank you!!!
  8. ATG
    You can upgrade to any socket P Merom with max FSB 800Mhz. Example T7300, T7500, T7700, T8100, T8300, T9300 etc..
  9. chipper13101
    chipper13101 Newbie
    Hi guys. Final upgrade was to update to a 7200 rpm hard drive to put the icing on the cake. I was surprised at how much more snap the 7200rpm hard drive gives vs. the 5400.
    Final setup on the Acer 5315 is:
    Intel Core 2 Duo t8300 at 2.4 ghz.
    3 gb ram
    7200 rpm 250 gb. hard drive
    Replaced french/english keyboard with regular english keyboard.
    Vista Basic.
    This is a very sweet little machine now. Works flawlessly.
  10. ATG
    Wow very nice upgrades, this thing must be flying now compared to the original specifications. Congratulations:)
